Technical Articles A central location for technical articles gathered from throughout the community and internet.
Air Filter Testing
Old 03-05-2014, 07:11 AM
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by southal cobalt
how long is the ac delco filter good for?
i went to a k&n because it was reusable, but i am definitely reconsidering running a stock filter
thanks for posting this
Check your owners manual. It mentions when you should replace it.
People on here will only tell you when they think it should be changed. I follow GM specs.
Originally Posted by Spawne32
It's an old test, but a good one, but the premise of the test isnt for performance. It's for filtration capacity and essential the "time to restriction". Pointing out that the OEM filter not only provided the best filtration but the longest usable lifespan. Alot of this has to do with the material being used, but given the fact that its a much older test, it doesnt take into account new filtration styles such as the AEM dry flow filters which were in fact designed by K&N which really are probably far superior to any aftermarket filter that was available at the time that test was done.
Meh, I'll still stick with oem.
I've tried alot of filters out (aem included), I've noticed no difference from any of them really.
Staged07SS is offline
Old 03-07-2014, 06:33 PM
cw383's Avatar
I've been looking for a suitable dry filter change form my K&N SRI. Has anyone come across one that fits proper?
cw383 is offline
Old 03-07-2014, 07:05 PM
xxenjoi11's Avatar
so if you've got a K&N intake, do they make a OEM cone filter?
xxenjoi11 is offline
Old 03-07-2014, 07:15 PM
No idea what model you drive.
I found a amsoil one that worked for the LNF
ECaulk is offline
Old 03-07-2014, 07:26 PM
06cobaltncng's Avatar
im really sick so excuse my laziness, but does this article mention the cheap spectre filter? I dont even feel like typing this....
06cobaltncng is offline
Old 03-07-2014, 07:27 PM
footballplaya3k's Avatar
No
footballplaya3k is offline
Old 03-08-2014, 03:35 PM
cw383's Avatar
Cobalt SS Turbo LNF. You would you happen to have the part number for that Amsoil filter?
cw383 is offline
Old 03-10-2014, 07:04 AM
Administrator
Administrator
Staged07SS's Avatar
No.
OEM will not be making a cone filter for an aftermarket intake.
Old 03-10-2014, 09:06 AM
Pitbull2o08's Avatar
No. OEM will not be making a cone filter for an aftermarket intake.
GMPP cone filter will work even though it's offset.
Pitbull2o08 is offline
Old 03-10-2014, 09:12 AM
Administrator
Administrator
Staged07SS's Avatar
Correct, it will, but it is not an oem filter.
Would I run it over a K&N though? Def.
Old 03-10-2014, 11:26 AM
  #36
umrdyldo's Avatar
So you guys are saying the GMPP filter will work on the K&N LNF intake?
Would it be better to just run the drycharger cover?
k&n drycharger - Google Search
umrdyldo is offline
Old 03-10-2014, 11:37 AM
  #37
Administrator
Administrator
Staged07SS's Avatar
No idea.
It will fit the K&N intake for the LSJ & the stock LSJ airbox with some modification.
Old 03-10-2014, 03:50 PM
  #38
Powell Race Parts's Avatar
The fact is, the stock air box on the LNF and on the LSJ REDLINE (not Cobalt) are able to flow a bunch of air, more than enough for most peoples mod requirements. The Cobalt LSJ is a little sucky, but the stock air tube with a stock air box ( with the bottom removed ) supported 400 hp on the Time Attack car.
And its clear in my testing that the K&N gets dirty fast, and no-one on here with a K&N cleans their filters as often as we did in racing. ( every 2-4 hours running time) . And the testing information supports that if K&N gets dirty ( and it does, fast) it dont flow much at all.
Therefore, in the clear light of day, hard to justify a K&N practically speaking. AND the koolaid drinkers will chime in and say " BUT IHAVE 500 + WHP I GOTTA HAVE A k&N !!"
OKay. So now after three weeks or so your filter is dirty and not flowing as much as a stock OEM air element. Where is the 500+WHP now?
wondering.
meh lol
Powell Race Parts is offline
Old 03-10-2014, 04:19 PM
  #39
umrdyldo's Avatar
Thanks for the posts. So unless we want to do massive amounts of upkeep it's not worth it.
now to find a good alternative. K&N lists inside diameter at 3.25 inches.
umrdyldo is offline
Old 03-11-2014, 07:16 AM
  #40
Administrator
Administrator
Staged07SS's Avatar
wondering.
meh lol
This.
My box:
Pretty much the same as running with no bottom lid, but will still support the stock filter. Win win.
Old 03-11-2014, 02:44 PM
  #41
So for the half of the LNF community that have the K&N SRI, what filter are we supposed to use?
Old 03-11-2014, 02:58 PM
  #42
Administrator
Administrator
Staged07SS's Avatar
I can't give you an answer for that. I simply posted test results I found interesting.
To be honest though, if I owned an SS/TC, I would run the factory intake & filter with the ZZP upgraded intake tube.
Old 03-11-2014, 03:15 PM
  #43
umrdyldo's Avatar
I'm switching to a shorter cleaning cycle. Probably close to every 3 months and I'm going to run an air filter wrap and call it good. Probably good to clean the MAF too.
umrdyldo is offline
Old 03-11-2014, 03:38 PM
  #44
Hockeyman's Avatar
I have the biggest K&N I could possibly fit on my intake
Guess i'm a sucker!
Hockeyman is offline
Old 03-11-2014, 03:55 PM
  #45
padlock's Avatar
I recently sold my K&N intake and am running my OEM intake/filter again. I changed my tune back to stock MAF tables as I had corrected my values for the K&N, and other than the ridiculous BPV/turbo noises being gone, the performance feels exactly the same.
If I ever do a mild bolt-on setup for AutoX I'll just be running the ZZP intake tube. Quite honestly you can get all the power you need in a k04 LNF with just a DP and tune, which is what I have now. Once it gets nicer out I'll be doing some logs to compare how my 60-100 times and IAT temps look compared to when I had the TR8 I/C and K&N dialed in on the car
padlock is offline
Old 03-11-2014, 05:51 PM
  #46
I like my turbo/bpv noises I've got to get a different air filter that's the correct size, pulled a ******* mistake and ordered a 3inch i.d. Instead of 3.5.
Def interested in the log differences between stock ic and tr ic
ECaulk is offline
Old 03-11-2014, 06:05 PM
  #47
I'd rather be safe and not have a shitty plastic IC and IC piping that will break at some point.
I'm interested in alternative filters if anyone can find any.
Old 03-11-2014, 07:00 PM
  #48
amsoil's new ea filters claim better filtration, while idk if its true or not you can just look at the universal cia filters and the dimensions and pick the one that will work
ECaulk is offline
Old 03-11-2014, 07:34 PM
  #49
Padlock got this figured out. Plastic may not be bling but it sure as hell doesnt heat soak like metal. For me its all about performance vs cost and durability. And keeping dirt out of the engine.
Old 03-11-2014, 08:11 PM
  #50
I'm about to the same conclusion, swap out for shows. Def would like to see actual data on the other filters than old out dated ones, but I'm not spending the cash to have them tested. Might see what I kind of a test I can design working at a mining R&D company does have its perks from time to time
ECaulk is offline
Quick Reply: Air Filter Testing
