Dyno results
Dyno results
www.tunetimeperformance.com
Next to the Cobalt ss click the links .
BTW all Graphs are from Hot cars most made 4-5 fourth gear runs . It would be easy to dyno a Cold car and make 8-10% more power .
Nice numbers. Very impressive. However, the 2.6 only made 8 more whp than the 2.8 pulley? You said 266 whp with 2.8 e/h. Yet the 2.6 has i/e/h yet it only netted 8 more hp? I guess that shows that the supercharger starts to lose its efficiency. It's turbo time
Originally Posted by sheek360
WTF?!? I just saw the dyno on there website. Why does the a/f lean out at 5800<ish>rpm? Where did you guys set C.O.T. and PP?
im really considering taking my car up there with the mods i have now! the power band looks alot smoother on the 2.8 w/ 42 pound injectors, then the 2.6!
then when the time comes ill upgrade!
i too am wondering how maxxed are the injectors ont he 43 pounders?
Originally Posted by CTCOBALTSSS
Hey ludicristSS, what was the duty cycle of the 42lb injectors from 5,500rpm on w/ the 2.8? Thanks.
Originally Posted by ludicristSS
C.O.T and PP why ? They are there for a reason . Spike is not there on any other runs we attributed it to the w/b going in a bung on the resonator
no dude, alot of people have been spiking at the same spot. you all have something in common.
They where no more then 78-82% fine they did go 88-92% with the 2.7 over 6600 A/F would get up to 12.4-12.8 by 6800 and power would fall off 50lb injectors would work nice with a 2.7
Thanks for getting the dyno sheets up. And anyone who is considering getting a tune from Tune Time, I would highly recommend them, they definatly know what they're doing and have some nice "goodies" in the works for our cars.
Isn't the tune going a little lean for the 2.6 pulley? Is there any knock and pulled timing when the AFRs reach the 13+ mark around 5200rpms, especially if the IAT2 temps are getting high? It seems like there's more power to be pulled out of the tune somewhere.
Nice numbers either way though
