1:1 Throttle
1:1 Throttle
I almost have it nailed
Ive been working a lot lately with custom Histograms and filtering and found some ways to tune the ETC Pedal vs ETC Plate and get it very close to 1:1.
When you get over 50-60% throttle, it will still outpace it a bit since we have the loads raising quickly for WOT but Im working on a balance of mid throttle loads and powerful WOT still. Shouldn't be long
Ill post a log later and some screenshots, this last update should have it where I want it!
Edit: This is not a hardset code or a TF trick, this is all done with tuning in HPT. Just thought I should add that.
I compared your latest to the previous and the mid load low rpm increases should help my LWFW situation. Too light a pedal = bog city on mine starting out.
Still futzing with my own issue today. lol
Going to the track tonight to hopefully see one of our guys get into the 12's. It will be hard not to run my car lol Ive been telling myself not to run the car at the track til I have $$$ saved up for **** that breaks haha
Im going to post up some stuff tomorrow morning. We ended up doing the clutch/trans in my car so Ive been driving it easy a couple days.
BUT
On my way home Friday I tried the new file and its just what we're looking for!! The car is very predictable now and at no point is that a hard spike of boost part throttle.
Another BUT
You can't make the car do 1:1 throttle. Not without removing the load based thinking inside the ecu, which would need a whole rewrite. This does not mean that its a fail tho. Lemme explain.
Eventho the plate is outpacing the pedal still under mid loads, I can now adjust it in a way that it holds a flat psi at that same pedal amount thru the whole RPM range! You can also fine tune it for different pedal amounts (say exiting different corners on a track) to hold different psi amounts and squeak the most power while maintaining traction still.
Ill post some screenshots, the logs and maybe even a vid of the boost gauge to see what Im saying.
BUT
Another BUT
mine goes from nice to ingorant at wot. it helps at the track i would say. i know it helps on the street some. im still debating on going with hp though. Since my trifecta tune is playing nice at the moment
