2.2 supercharged
2.2 supercharged
ive got a tuning question I have a 2.2 vvt ecotec and im running a m62 supercharger and I have 60lbs injectors ready to install but my buddy tuning it says the stock injectors are not even close to maxing mayb 40% duty cycle if that sounds right. does that make any sense? were using hp tuners by the way and its at 7lbs of boost and the wot air fuel ratio is high 11's low 12's afr. and also im running a maf sensor and at cruising speeds around 2500 rpm it throws a mass air flow code and falls on its face. but under wot its fine any suggestions?
ok well were running the stock 2.2 injectors and he says there fine for what im running but it just makes me worry lol I bought lsj ones and 60lb dekas but I guess ill save those for when I pulley down
z28addiction
09-28-2015 12:03 AM
