2.4 LE5 Tuning FAQ
Old Jan 12, 2008 | 07:23 PM
REDFOCZ's Avatar
Yeah in the airflow tab>Dynamic airflow,
Set enable to like 500RPM & disable to like 600 RPM
This will force the car in to a trust MAF only, to force it into Open Loop I have to look at the program I cant remeber it off the top of my head, been awhile since I have done MAF tuning on my car.
Old Jan 12, 2008 | 08:07 PM
pjk91's Avatar
he asked the same question on hpt. should answer him there too, that will make sure he sees it!
btw...fred and i (mostly fred) worked on the tune some more on Thursday. It's pretty well dialed in, but we still get the lean spike just before going into PE. I'm going to max out the enrichment rate at 2.0 just to see what it does...currently its at 1.0 and we still get the spike for a split second. The hesitation is driving me nuts. It's the first e67 he's seen so it's possible we are missing something. Any ideas?
Old Jan 13, 2008 | 12:07 PM
an0malous's Avatar
thank you so much!!
Old Jan 24, 2008 | 08:42 PM
Mallard's Avatar
You can run in open loop by disconnecting your stock O2 sensor.
Old Feb 23, 2008 | 03:21 PM
steddy2112's Avatar
Will the no lift shift mess with rev matching down shifting?
Old Feb 23, 2008 | 05:08 PM
REDFOCZ's Avatar
Only if you are trying to match a rev over the 4000 RPM rev limiter.
Old Feb 24, 2008 | 08:49 PM
steddy2112's Avatar
HPTuners and a laptop
Old Apr 6, 2008 | 11:08 AM
REDFOCZ's Avatar
Damnit, I cant post any more pics for the how-To
Old Apr 6, 2008 | 02:22 PM
pjk91's Avatar
i can host. email me at patrick@negmsc.com
Old Apr 6, 2008 | 02:40 PM
REDFOCZ's Avatar
It's not a prombelm hosting the pics. Its I can not add any more to the first post.
Old Apr 6, 2008 | 04:28 PM
  #36
pjk91's Avatar
oh gotcha. pic post limit. maybe a mod can force them in.
Old Apr 19, 2008 | 07:26 PM
  #37
celicacobalt's Avatar
What if any ammount of knock is safe? Ive heard of some being ok for 4 cylinder engines.
Old Apr 19, 2008 | 07:51 PM
  #38
REDFOCZ's Avatar
Knock is knock it's not good. But I start adjusting the HO table if I am getting over 2-3*'s
Old Apr 19, 2008 | 08:02 PM
  #39
fbaero10's Avatar
this is awesome
Old Apr 19, 2008 | 08:12 PM
  #40
REDFOCZ's Avatar
I take it you have never seen this thread before
Old Apr 19, 2008 | 08:14 PM
  #41
fbaero10's Avatar
no sir.. im debating on buying hp tuners.. wanna email me a file or something or make a trip up to pa lol
Old Apr 19, 2008 | 08:16 PM
  #42
REDFOCZ's Avatar
Buy me a plane tiket up on a Tuesday I can tune it on Wed and fly back on Thursday and yeah. Heck Id cut you one hell ofa deal if you did that. I would be able to visit my sister in Allentown
Old Apr 19, 2008 | 08:32 PM
  #43
fbaero10's Avatar
im game man i searched tickets its like 200 for a plane ticket
Old Apr 19, 2008 | 09:16 PM
  #44
so 2-3 is acceptable?
Old Apr 19, 2008 | 09:27 PM
  #45
REDFOCZ's Avatar
Me personaly I dont sweet it too much. Others may, but from my research and my logs 2-3*'s is ok. But Your also boosted any thing over 3 I would want to fix.
Old Apr 20, 2008 | 10:01 AM
  #46
BennyHHR's Avatar
Any is not good. Not that it'll hurt the engine, but the KR, even at low levels of detected knock, will pull timing for a bit to protect the engine. That can be up to 8*.
The problem with consistant KR is that the ECM's algorithms will compute a Knock Learn Factor, which essentially "averages down" towards the Low Octane Table, pulling timing throughout. That's not desirable.
Also determine if any detected knock is real or false (that can happen!). Try higher octane and if the KR is still there, likely false knock. Also, if timing is pulled and it's still there, false also. If that's detemined to be true, then consider de-sensitizing the knock sensor values some.
Best to get rid of it overall.
Old Apr 20, 2008 | 10:48 AM
  #47
So, lets say to be on the safe side i allow 1* knock. That would be cool right so that i dont have to give up more hp.
Old Apr 20, 2008 | 10:59 AM
  #48
fbaero10's Avatar
yo man.. your in pitt.. can you do tunning for my ss 2.4? ill make the trip or maybe meet up at a meet or something.. id love to check out ur car too
Old Aug 13, 2008 | 12:54 PM
  #49
jeanbalt's Avatar
great thread
helped me out alot in tuning my first 2.4
got him tuned - no knock - and running 91 - told him to go up to 94 octane see if
I can notch up the timing a bit ... for 2-3 $ a tank not a big price to pay
********* if the car shuts down while doing a flash don't panic ******************
********* some 2.4's will only respond to a write entire *********************
Old Aug 13, 2008 | 05:12 PM
  #50
yeah my 2.4 has to write entire for every change
