Advice on Boost Reduction + Timing
Old Aug 28, 2008 | 08:27 PM
rrutter81's Avatar
Just curious if anyone has any advice for boost reduction and target timing for launching from a dig?
Any info would be cool and thanks!
really dont want to use ETC manipulation..... bump
Old Aug 28, 2008 | 08:29 PM
heyitsmikey1987's Avatar
i used hptuner to kicked down my boost in first when launching its at 75%
Old Aug 29, 2008 | 08:31 PM
rrutter81's Avatar
i reduced mine to 50% and i still burn through the gears. You still stock or staged?
Is it true 2nd gear reduction reduces all the gears post 2nd gear?
Old Aug 29, 2008 | 08:43 PM
lsjwannabe's Avatar
Yes on 05 and 06 cars not or 07 i believe. What works a little better i have found is a nice slow ramp and see how it works for you.
Old Aug 29, 2008 | 08:47 PM
Raven SS's Avatar
driveshaft shop stg 2 axles..
and some mickeys
Old Aug 29, 2008 | 08:51 PM
rrutter81's Avatar
and some mickeys
only reason i havent gotten s2 axles is because i heard the tranny will grenade on you. The weaker axles are better as a safety mechanism so that if you break something its only 500.00 instead of 2000+
correct me if im wrong.
could you give me an example ramp up?
also im guessing anything before 4000 rpm the boost is limited as well? not... 100% boost until the hptuner's can read and then reduce to 50%? Sorry about the questions, i have alot to learn on how hptuners is handling our S/C and torque.
My current tune with boost is 50% 70% 90% then 100% throughout in first
Old Aug 29, 2008 | 08:53 PM
lsjwannabe's Avatar
On the trans thing with those axles thats not entirely true although it did lead to the destruction of mine that is a ver isolated incident in the broad spectrum of things.
As for the boost question say start at 35% and go up in incrimints of 5 or 10% whatever will work for you, you just need to keep trying a few different methods and you will get it down.
Old Aug 29, 2008 | 08:58 PM
rrutter81's Avatar
well i like reliability over anything.... i may get it cryod with the s2 axles and see how that runs or even a custom rebuild from shepard.
You have been most helpful lsj, thanks for the info.
Same for you raven.
Old Aug 29, 2008 | 09:01 PM
lsjwannabe's Avatar
No problem
Turbo Johnny
Feb 21, 2019 09:41 AM
Cptnslo
Sep 24, 2015 09:32 AM
TylerJHowell
Sep 21, 2015 06:47 PM
jcalvin1126
Sep 11, 2015 10:24 AM
medic710
Sep 6, 2015 08:53 PM
