Back from Tune Time Performance in NJ...
#127
#128
Since we are basically at sea level in the winter the dyno multiplies the raw numbers by a number < 1 depending on temperature, humidity and barometric pressure. This allows us to compare corrected hp/trq with other pulls that are made at higher elevations and with different weather conditions... My two pulls the other day were 1hp apart and were 275ąhp without the weather correction...
#129
thanks for the detailed explanation! i guess next time i drop by there ill have to ask because i want to know the weather corrected to find out what im really running you know
damn i wanna make the power your making though... that is great!
#130
It was actually funny after he made the first pull with my car he looked at me and said "well I think we're done here..." I was like why? He basically said for what I have done he has never seen those kinds of numbers... He did a second pull I guess to confirm what he was seeing which was - 1hp and unplugged his laptop... I'm not complaining.
#132
Really if you look at my dyno from August with only an intake and Stage II I was only at 223whp. I really think I just stumbled upon a good combination of mods. The header I have in particular was really impressive to me... Also I can't sing the praise of that Magnaflow exhaust enough for the $558 I paid for it shipped...
#133
#134
When you are ready to buy that exhaust let me know I will show you an awesome trick that will save you a ton of cash...
#135
#137
thank you so much i really appreciate the help!
allrighty gonna head out so maybe all see ya on the boards our at tune time at some point take care and its been fun!
#138
https://www.cobaltss.net/forums/north-east-56/spring-08-tri-state-area-dyno-day-meet-98015/
#139
FYI, we are putting together a dyno day at Tune Time for CobaltSS.net members on April 12th...
https://www.cobaltss.net/forums/showthread.php?t=98015
#140
Well it just depends on what kinda of dyno u want to compare it to. Like a lot of people on here get their dynos done on a dyno jet, which tend to give u higher #'s because its not weighted, but the Mustang Dynos are weighted and gives u a "real" whp #. Correct me if im wrong guys.
later
later
The Mustang chassis dyno uses an Inertia load as well as an eddycurrent brake load to simulate the "actual" load (combined aerodynamic plus rolling frictional load) that the vehicle would experience when in motion.
Because when a manufacturer gives a hp figure for a certain vehicle's engine, they're definitely NOT figuring in for aerodynamic drag.
For me then, that article now formally ends the debate regarding chassis dynos.
I'm only interested in using the "non-aerodynamic loss configured" dynos.
Dynojets are the way to go people ...
#142
#146
#150
