cool trick with fans in HPT
today i was messing around with HPT and the fan control to see if i could get the car to run cooler then 185 so i start playing with the settings just to see what happens....and i ran across a cool setting.
i run the fans 100% in the summer so i only know this works with the fans set to 100% like this...
so i started playin with the "output control VS current state" tab.....
you'll notice that fan 2 doesn't turn on until the car has heated up more....
so i made fan 1 and fan 2 match...
then i made them all "1" which in this case means there always on, regardless of the ECM "Output control"....like this....
this had a good effect.....the fans turned on rite after the re-flash was done....thought it was both good and bad cuz now i thought they were going to run 24/7 so i was changing the output control back to having fan 1 and 2 match when they shut off.....
so i started the car drove a bit then came into a parking lot and shut it off....the fans run with they key out of the ignition and even with the doors locked for about 30-40secs then they shut off....its a very cool trick to keep the car from heating up when you shut it off on a hot day.
what your fan setting should be is the fan should be on until your car reaches a certain temp like on my old car when i shut the car off it would stay on until the coolant was cool enough
It is possible to cool your engine too much, its also a waste of energy and in turn gas millage. The stock setting has be tested time and time again, so why mess with something proven? Especially since it is such a radical change.
Moderator Alumni
running them all the time will probably cause them to fail prematurely.
I don't see any reason to run them when the car is moving and the natural air flow is cooling the car.
there is another reason for not doing it....it was brought up before and I cannot remember why right now..??
if you come off the highway fast enough and come to a quick stop you can hear them turn back on, so i beleve they turn off above a specific speed.
the stock system have been tested to stop the engine from over heating, not keep it in its optimal heat range....the 180-195is range.
as for MPG thats the LAST thing i worry about....getting the best possible performance out of my car is what i'm after.
and as for the "running them to often might kill them" idea....if they die out on me, i'll let ya'll know...its nothing special tho...12V DC "brushed" electric motor...they've proven them selves to last a long time on many cars!
and to address the "over cooling" thought....yes the LSJ was designed to run in the 180-190 range....a bit cooler then most engines if you think about it tho...normal is in the 210 range
so be useing our stock 180 t-stat and the fans i can keep it under the 190 range...normally the car with this fan set up runs 181-187 and thats rite were i want it....plus with the fans on there constantly pulling air over the duel HE's so it helps with AIT 2 temps.
The enigine needs to warm up to its optimal operating temp and I'd be too afraid this would prolong the warm up time. Its true that a cool engine makes more power but a cold engine run hard can cause damage!
Be very careful with this.
now take a stock car and run it in stop and go traffic(much like i'm in all day) and watch it go up and into the 200's then both the fans kick on 100% and it comes back down in to that 185-190 range.....
i simply want it to run in that range all the time.....
HPtuners won't let you do 170 or 180. The lowest temp you can change through hptuners is 192 i belive and that will basically run your fans all the time, as soon as you start the car up. The next one is 196, which is where I have it kick in.
i had a cavalier that came into my work with a bad cooling fan relay causing it to run even with car off so i fixed his problem and took the relay for my own use before a run down the track. and took it apart to make sure the contacts kept the fans on but, its only for one fan. i thinks its an alright idea, considering i can afford hptuners yet.
