Does MAF read Voltage first then convert to Frequency?
Old Jun 22, 2008 | 12:01 PM
RedBaseBolt's Avatar
Just like the title says. What type of MAF do we use? One that reads Voltage first and then converts to frquency? Or does it read and output purely in frequency?
Thanks.
Old Jun 22, 2008 | 02:54 PM
light'bolt's Avatar
I read somewhere the output is a square wave freq. Don't quote me on that though.
Old Jun 22, 2008 | 03:54 PM
You're correct. However I need to know if the sensor reads votage and the box that it's connected to within the sensor converts it into a frequency or the sensor reads frequency and simply relays it back to the ECU.
Old Jun 22, 2008 | 04:13 PM
REDFOCZ's Avatar
Why are you going to try and run the SAFC type of device on your car, because if you are it will not work. one of the local 2.2 ions around here tried running one and messed his car.
Old Jun 22, 2008 | 04:54 PM
I've been trying to get my AEM FIC installed and I need a way around the MAF outputting only frequency.
Either I need to know if the sensor reads voltage or I'm going to have to use a digital to analog converter.
Old Jun 23, 2008 | 09:34 AM
light'bolt's Avatar
I did just a little research it looks like the maf is current driven. Current is passed thu the sensor heating it and as it cools from the air passing thru you get a change in current. The output of this current is used to change the freq.
Using ohms law, the resistance of the element changes as it cools, if your resistance increases your current drops and the voltage, theortically, should stay the same.
Old Jun 23, 2008 | 12:25 PM
I called AEM directly and asked a technician about the use of the FIC on my 2005 Cobalt.
Question: Is the Cobalt 2.2L MAF Frequency based or Voltage based?
Answer: The tech believes that the cobalt should use a 0-5V sensor and doesn't understand where I got the idea that it uses a frequency based sensor.
Question: I asked if the FIC was tested on a Cobalt SS or 2.2L
Answer: The FIC was tested to work on the 2.2L
Question: I asked if it can function with the MAF hooked up then can I still run the controller without hooking up the MAF.
Answer: yes the only function that will be lost is MAF Clamp.
In accordance with the above information from AEM I'm going to by pass the MAF all together and see what I get this weekend.
Last edited by RedBaseBolt; Jun 23, 2008 at 12:25 PM. Reason: Automerged Doublepost
Old Jun 23, 2008 | 06:54 PM
Update: I tried switching the MAF from percentage mode to Voltage mode as suggested by AEM tech but no luck. I'll have to bypass this weekend.
patooyee
Oct 15, 2015 05:11 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
dennis69
Sep 28, 2015 02:16 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
