Frequently asked HPTuner questions
DISCLAIMER - I AM NOT RESPONSIBLE FOR THE CHANGES YOU MAKE TO YOUR CAR
Ok, let me go one thing at a time..
The rev-limiter
Engine>Fuel Control>Fuel Cut-off>RPM Limits
change the Fuel Cutoff RPM P/N vs. ECT to your desired rpm
change the Fuel Cutoff RPM vs Gear to your desired rpm
change the Fuel Cutoff RPM 1st Gear vs. Time to your desired rpm
Eliminating the rear O2 sensor
Engine Diagnostics>DTC's
for the following codes, uncheck the SES option and set the ERROR MODE to 3-No Error Reported
P0036
P0054
P0136-P0141
P0420
I believe thats it, all the ones you want to turn off are labeled HO2S..........sensor 2
For those without a cat, also turn off COT (set the values to 0)
Engine>Fuel Control>COT Lean Cruise>COT Adder Max
Engine>Fuel Control>COT Lean Cruise>COT Adder Min
Now, I use another couple tricks.
Limited boost in first
Engine>Torque Management>Supercharger>Max Boost 1st Gear
Labels 4000/4250/ 4500/4750/5000/5250/5500/5750/6000/6250/6500-8000 (at 100%)
Max Boost 40/45/55/60/65/75/80/85/90/95/100
Torque Management
Engine>Torque Management>General>Spark Retard vs Torque Reduction
set all values to ZERO
Transmission>Torque Management>Abuse Mode>Trans Abuse Mode Torque Reduction vs. RPM
Transmission>Torque Management>Torque Reduction>Torque Reduction vs Torque vs Shift-Normal
Transmission>Torque Management>Torque Reduction>Torque Reduction vs Torque vs Shift-Performance
these are simply ways to accomplish a goal.
The rev-limiter
P0036
P0054
P0136-P0141
P0420
Torque Management
Like Doc said, the basics have been done by many already. Your best bet is to check with either Cameron or Steve if/when you get HPT. I think they both may have basic 60lb tunes for you to futz with.
For those people who are worried about their MPG i suggest reducing boost in 1st gear. I have mine set similar to Docs and i easily gained 2 MPG without planning on it. Changed it back too 100% across the board just to make sure it wasn't the weather and my MPG instantly starting dropping off.
What does zeroing out all the torque management stuff actually do for you? Quicker throttle responce?
<--still an hptuners noob guided by the wings of the one and only Denny
wow this program seems to be what i needed... is there anything it doesnt do. will it work on the wifes 2.2 and my 2.0 or just my car. wow ive got so many questions right now i dont know where to begin.
ive got friends that do alot of stand alone systems for all kinds of cars and are very very good at it. its not hard for them to find out what works on what and what doesnt so it wont be hard to get something to work.
check out the electromotive tec3 it would wok wonders on this car
http://www.electromotive-inc.com/products/tec3.html
add this to the list if u like
adjust computer for 60lb injectors
engine>fuel control>general>flow rate vs. kpa
50.19823 50.73302 51.26297 51.87334 52.39167 52.90515 53.41282 53.99993 54.49694 54.99105 55.47934 56.04514 56.52471 57.00041 57.47223 58.01769 58.48176 58.94196 59.39828 59.92629 60.37486 60.82150 61.33692 61.77580 62.21177 62.64387 63.14476 63.49257 63.49257 63.49257 63.49257 63.49257 63.49257
Ive found this to work extremely well and the long term and short term are just as good if not better then stock
if you were all wondering also I found a spread sheet in another thread that produces these numbers
P0036
P0054
P0136-P0141
P0420
hey doc you forgot one..... I managed to throw this code while finding all the codes to throw that pertain to removing the cat and the 2nd o2 sensor
P2AO1
P0036
P0054
P0136-P0141
P0420
P2AO1
P2AO1
P2AO1
