Frequently asked HPTuner questions
Old Jul 25, 2007 | 02:18 PM
BriantheLion26's Avatar
We need a good how-to on how to run hp tuners or is it that difficult to teach effectively? I wouldn't mind knowing how to tune my own car with hp tuners, atleast some of the basic changes. All these words I keep seeing, VE this and that, I just have no idea what it means.
Old Jul 25, 2007 | 08:40 PM
Doc's Avatar
Doc
Post
some helpful links
HPTuners - Getting Started
Injector scale worksheet
Injector Duty Cycle converter
Speed Density Tuning
Installing a XD-16 & LC-1
How to connect an AEM wideband
Old Jul 25, 2007 | 09:02 PM
mike25's Avatar
hey doc...ive been reading up on how to tune for boost....i know i need to uprgrade the injectors and tune that...so im guessing your idc calc. link above will help me with that aspect.....where do i go from there?....i would greatly appreciate it if you would head over to my tuning a 2.4 for boost thread an take a look at that for me...
Old Jul 25, 2007 | 09:58 PM
Doc's Avatar
Doc
pm sent
Old Jul 25, 2007 | 10:12 PM
ItalianJoe1's Avatar
gonna subscribe to this for the helpful links!
Thanks Doc!
Old Jul 25, 2007 | 10:13 PM
Doc's Avatar
Doc
No problem. I'll get you back when I am able to.
Old Jul 25, 2007 | 10:19 PM
CHARGDSS's Avatar
yea im definitely gonna have to give those links a read. thanks doc. so far all i have accomplished is using a file denny was sending me and changing AFR and timing to what i wanted. I think i want to start fresh. Or atleast learn y things are this way and thay way.
Old Jul 25, 2007 | 10:55 PM
Doc's Avatar
Doc
He's a good resource too. He doesn't have a lot of time to come on anymore but I'd bet is still willing to help out fellow tuners.
Old Jul 26, 2007 | 11:23 AM
Area47's Avatar
Rent me! per hour
if you have an 07, i can help you out with little things here and there.
timing tables will affect MPG more so then a boost limit will
Old Sep 6, 2007 | 10:22 PM
NightriderCobaltSS's Avatar
cool thanks frank
Old Sep 6, 2007 | 10:32 PM
  #36
SJSchafer's Avatar
Originally Posted by Z Speed
add this to the list if u like
adjust computer for 60lb injectors
engine>fuel control>general>flow rate vs. kpa
50.19823 50.73302 51.26297 51.87334 52.39167 52.90515 53.41282 53.99993 54.49694 54.99105 55.47934 56.04514 56.52471 57.00041 57.47223 58.01769 58.48176 58.94196 59.39828 59.92629 60.37486 60.82150 61.33692 61.77580 62.21177 62.64387 63.14476 63.49257 63.49257 63.49257 63.49257 63.49257 63.49257
Ive found this to work extremely well and the long term and short term are just as good if not better then stock
if you were all wondering also I found a spread sheet in another thread that produces these numbers
I defer you to this thread:
https://www.cobaltss.net/forums/tuning-131/1st-setup-injectors-flowrate-rate-modifier-min-pulse-width-pw-adder-69454/
Old Nov 20, 2007 | 12:38 AM
  #37
jimbos'ss's Avatar
subscribed for learning purposes
Old Dec 7, 2007 | 11:14 PM
  #38
powerz's Avatar
same and if any one has tunes they are willing to share so i can do some comparing it would be much appreciated
Old Dec 8, 2007 | 12:45 PM
  #39
LopsidedJester's Avatar
What are the best widebands to use with hptuners? i plan on buying hptuners in the future, but i read that only 0-5v output wideband a/f gauges can be used. I was set on getting the 6178 autometer cobalt wideband gauge, but it only says 0-4v output
Old Dec 8, 2007 | 12:50 PM
  #40
SJSchafer's Avatar
LC-1 FTMFW!!
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
Adecker
Oct 20, 2015 09:46 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
