2.4l boost tuning...is it possible?
Old Dec 11, 2007 | 08:26 PM
mike25's Avatar
well im about to begin buying turbo parts and im just curious what everyone thinks on wether or not the 2.4l is boost tuneable
Old Dec 11, 2007 | 08:28 PM
steddy2112's Avatar
Ask Beck, his is supercharged
Old Dec 11, 2007 | 08:43 PM
mike25's Avatar
would you consider his tuning for the supercharger the same as what you would do for a turbo?
Old Dec 11, 2007 | 08:44 PM
steddy2112's Avatar
Are you not forcing air into the manifold and using boost?
Old Dec 11, 2007 | 08:52 PM
mike25's Avatar
yea but i wasnt sure if there were different aspects of the tuning involved with a supercharger
Old Dec 11, 2007 | 08:54 PM
steddy2112's Avatar
Go to like, borders or barnes and nobles, and look for a F/I book and read it...I know Adam has read a few books(NJHK) and knows quite a bit about it...but you are still generally pushing a whole bunch of air into the car...
Old Dec 11, 2007 | 09:01 PM
mike25's Avatar
i know plenty about f/i...just not alot about tuning...just wondering if the tuning aspects were pretty much the same or not
black07ssc's Avatar
yes the tuning will be different with a turbo
Old Dec 11, 2007 | 09:03 PM
steddy2112's Avatar
Depeneds how far you go into it...how far into it are you gonna go?
I would think that it wouldn't be too much different below 8 PSI really...a lot less heat?
Old Dec 11, 2007 | 09:27 PM
mike25's Avatar
im only planning on about 8psi for starters
Old Dec 12, 2007 | 09:56 AM
foff667's Avatar
The methods will be similar but different, ie a cobalt will hit peak boost very early whereas a turbo will take time to spool up, same goes with a centrifugal supercharger in that the boost for them is relative to the rpm your spinning at. Roots style blowers give you tons of boost right off throttle. Can it be done? yes. Is tuning a turbo different from SC'd tuning? yes.
Old Dec 12, 2007 | 10:00 AM
pjk91's Avatar
It's defintiely different. IE you can't get a tune from an ss/sc and flash that on your 2.4. Bad things would happen. PE will have to enter at different rpms/throttle pos and theres way more to it than that.
Old Dec 12, 2007 | 03:38 PM
mike25's Avatar
how much different would it be? would it be different fuel and spark settings all across the rpm band or am i wrong? the only successful custom turbo and hptuned i know of was ppazz...but then again when i think about it i believe he has been the oly one to really try it...
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
