Help me reduce knock.
Old Mar 1, 2007 | 09:18 PM
Admiral Jedi's Avatar
My Stage Two Cavalier (lol). It's related. It's the 2.2 with the M62 Supercharger. 3" pulley. Dual pass installed.
My iat's are under 100 degrees most of the time, and once today I saw them go above 100. That's cooler than what I was on the stock pulley with the stock intercooler.
I have NGK Iridiums (two stages colder than stock).
My afr under wot is 12.8:1. It's leaner than I'd like.
The problem is this: I'm getting 7 degrees of knock. I don't like that.
What do you guys do to reduce knock? I don't have HPTuners available because it won't work with my ecu.
So my options are this:
1. Retard Timing with my DIS-2.
2. Water Injection.
3. Raise fuel pressure on already strained injectors.
4. Megasquirt.
5. SAFC
I'm leaning towards Water Injection and if I still get knock, I may retard with my DIS-2. What are your thoughts? Tips? Advice?
Old Mar 1, 2007 | 09:20 PM
distillion's Avatar
what gas are you running?
Old Mar 1, 2007 | 09:21 PM
CTORANGESC's Avatar
Do a search somebody had a solution to knock froma couple days ago.
Old Mar 1, 2007 | 09:25 PM
memphisr24's Avatar
Use 94 octane if it's available, or even 100 octane. That will definately get rid of the knock for sure (100 octane) and you can possibly even add some timing
Old Mar 1, 2007 | 09:32 PM
cheesecake's Avatar
he is on 93 octane
Old Mar 1, 2007 | 09:35 PM
memphisr24's Avatar
Is that a cavy with srt4 rims??? Doesn't look that bad
Getting back, If I were you, retard the timing until you get a hptune so you don't blow something up
Old Mar 1, 2007 | 09:38 PM
rnjmur's Avatar
can you not get any bigger injectors? If you could get the afr richer that may get you to where you need. The other option I would go with would be water injection.
Old Mar 1, 2007 | 11:24 PM
I'm leaning towards Water Injection. What wonders has it done for you LSJ guys?
Also: which kit would you recommend?
Extreme Dimensions
Jun 29, 2016 11:01 AM
vjoel2011
Oct 2, 2015 12:11 PM
OPCrer
Sep 27, 2015 08:11 PM
Dustonian131
Sep 23, 2015 08:03 PM
bucks121
Sep 12, 2015 07:39 PM
