HP tune question
HP tune question
hello i have had hptune for a few months now and am almost ready to add it to my car
just a few questions first
I have installed my CAI
i am gonan put on a tune from Psykostevo he has a trany and a engian tune.
should i have anything else on my car or any other tweeks done first.
also i see people talking about AF ratio should i have a gauge for af
You NEEd an AFR gauge to check for AF. You cant really do too much with a stock pulley and just an intake. You might be able to play with timing and you would be able to fix your afr if you had an afr gauge. What do you mean by a tranny tune. Im guessing that just means he took off his Torque management in his tranny. Also what are his mods. If they are sort of like yours and he was tuned in a dyno or with an afr ratio and chekced for knock you should be fine.
You will probably need to calibrate you MAF if you continue to experience problems or CEL's. Each car will behave a little different. And a Wideband never hurts.
The 2.4L Level 2 is a solid tune. The only issues will probably MAF differences from his intake.
I really wouldn't recommend it for your use until you get those cams then it is almost certain you will need it.
BTW.....I haven't sent you the tune yet have I?
no i am gonan send you my backup here in a bit
i dont know if i am gonna put the cam in i might sell it and just do boltons
the reason is my car is a lease i was gonan buy it but i will get a newer can when the lease is over i want a SS SC,
