hptuner
Old Oct 24, 2008 | 06:22 PM
BMXIN749's Avatar
hptuner
can someone honestly just tell me if getting an hptuner would solve my problem of this stupid emmisons crap..i have a check engine light which is an automatic fail and im sure its runnnin to think so would an hptuner be the solution and if so which version the basic package or good one should i buy?...despirite for some answers
Old Oct 24, 2008 | 06:25 PM
light'bolt's Avatar
kind of expensive just to clear a CEL. Won't an autoparts store clear it for you?
Old Oct 24, 2008 | 06:30 PM
BMXIN749's Avatar
hptuner
well the thing is i live in md and every 2 years we have to have emissions toensure our cars are running correctly. With my high flow cat its throwin a code so i wanna clear that off...yes autozone could clear it off but it will just come back on im sure
Old Oct 24, 2008 | 06:54 PM
Doc's Avatar
Doc
drive down here and I'll do it or spend $499 on the basic and do it yourself.
Old Oct 26, 2008 | 11:22 PM
jeanbalt's Avatar
2 choices find a tuner in your region -- there is a directory on this site
With the hp tuners program it will disable the specific code so your light doesn't
come on that will be much cheaper than buying hp tuners
and at the same time you can get a tune ... worth the while
if your high flow cat doesnt pass standards anyways you need to get
the stock part back on get tested -- you can get a scanner for 50-70$ and
that will reset your codes
Old Oct 26, 2008 | 11:23 PM
1badBlueberrySC's Avatar
Get an OBDII scanner and it'll clear all codes....
Old Oct 26, 2008 | 11:31 PM
jeanbalt's Avatar
Only problem is that that code in particular will reoccur
so unless he deletes it at the garage and then crosses his fingers
hoping it doesnt happen during testing ...
it just depends on how quickly it reappears
here is more info as previously discussed
https://www.cobaltss.net/forums/tuning-131/tuned-cars-failing-inspection-135470/
Old Oct 27, 2008 | 12:52 AM
Hockeyman's Avatar
spark plug anti-foulers, get a pack of two for $4, drill one out. put them together, then put the o2 sensor on it. Or you could spend $30 on an ARK CEL eliminator which does the same thing.
Old Oct 28, 2008 | 11:47 AM
sscharged112's Avatar
There is a problem with clearing the codes right before you go to a garage... When you clear the codes the computer runs a diagnostic for about 100 miles... When the mechanic hooks up the emissions test to the car, that message (car not finished running diagnostic tests) will show up and they will not test the car....well not in MA anyways. I miss the good old times.... Throw in an extra 10 and a six pack and the garage would pass you lol
Old Oct 28, 2008 | 12:29 PM
Dainslaif's Avatar
This is what I did (but I only used one) and haven't thrown a CEL from my catless pipe yet.
DarrenGC
Dec 24, 2021 01:55 PM
Adecker
Oct 20, 2015 09:46 PM
Hugger1975
Oct 15, 2015 03:28 PM
n20saturn
Sep 21, 2015 01:50 AM
barthello
Aug 28, 2015 11:41 PM
