I need a modified stage 2 tune...
Old Oct 19, 2008 | 10:32 PM
boosthard05's Avatar
I need a modified stage 2 tune... fuel, timing, tq management removed...
somthing to hold me over for a little while... were having some tuning issues and need a good modified GM STG2 tune so i can have somthin on the car while we figure out whats wrong with this other tune.
i may use the stg2 tune as a base map if it's good enough tho.
Old Oct 19, 2008 | 10:44 PM
06superchargedbalt's Avatar
Yeah that's what I am doing, until my tuner gets a wideband..and then it's ***** to the wall!!! Good luck man!
Old Oct 19, 2008 | 10:46 PM
Thats my same problem... i need to install my wideband but am clueless on how to wire it up, so untill i can get it in, i need somthin safe to run.
Old Oct 20, 2008 | 01:45 PM
uwishuhdmyecotec's Avatar
you can get stage 2 from the repository.
Old Oct 20, 2008 | 01:49 PM
hatrickstu's Avatar
tell you two what. IF i have time today or tomorrow ill throw one together on my desktop and send them your way
ill remove TQ man, but im going to leave 85% in first because you do need it
ill turn on the fans and IC pump so you can have them run in the ACC position
Old Oct 20, 2008 | 02:32 PM
SWWEEEEEET! Crossing my fingers
Old Oct 20, 2008 | 08:43 PM
thats wassup... but i have a redline i was told the coalt tune wont work corectly due to maf placement...
Old Oct 23, 2008 | 02:51 PM
REDFOCZ's Avatar
All you have to do is modify the MAF curve by logging the car using your FT's till you get your WB in. Not as accurate as tuning of AFR error but it will get you in a ball park range.
Old Oct 23, 2008 | 06:18 PM
Should i log off of STFT or LTFT?
Old Oct 23, 2008 | 07:48 PM
REDFOCZ's Avatar
Some say use STFT others say LTFT, but the fact of the matter is. Everytime I log the car I reset the fuel trims the avg is the same. Or you could set up a custom pid that takes the avg bettween LTFT &STFT and use that. You have a few options
Old Oct 23, 2008 | 07:51 PM
Sizzle06's Avatar
Hit up OTTP,josh would be able to help you.
Old Oct 23, 2008 | 11:01 PM
REDFOCZ's Avatar
Can Tunes not really the best solution. Unless Josh will help you after the base tune to dial it in. Other wise not the best solution.
Old Oct 23, 2008 | 11:04 PM
^^True... Cannot wait till my tuner gets his wideband...how much good does tq management deletion do?
Old Oct 24, 2008 | 12:24 AM
So can someone give me a step by step walkthrough on how to modify the MAf curve? im getting KR at the top of 3rd gear and nowhere else... someone else who had the same problem said its because i need to tune the MAF...
if there is a way to do it without a wideband i would love to know because this tune seems to be pretty good other than the KR up top... im running 20* of timing right now with no KR anywhere but the top of 3rd... and we have scaled it back at least 5-6 degrees with no luck... i would like to be able to run 25* again because the car pulls like a beast when it's running that much timing...
on 20* i took out a DSM the other night with a built short block, cams, bullseye 57mm turbo, open downpipe and some other ****... walked him down by 2 cars from 40-75ish...
im sure i could have walked him much harder running at full potential.
Old Oct 24, 2008 | 10:16 AM
REDFOCZ's Avatar
Quick answer set up a histogram logging the MAF by both the STFT's and the LTFTs. When you go out to log your car make sure to reset the FT's and then copy the results out of the histogram, I use the LTFT one and copt by % half into you MAF table on the tune. After a few attempts doing this you will notice the MAF will be off by less and less. You want your MAF error between -2% and +2%
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
