Interceptor gauge?
Interceptor gauge?
Ok so im debating if i should take the hour trip to get one its only 100 bucks but im new to it and have alot of info but a few things i havent found out.
-now u can read ur a/f levels and knock retard and stuff but can u adjust them with the gauge to or no?
And if anyone has any info from people who have one if there is anything else i should know about it like, is it really easy to use or no and stuff like that gauge im getting dnt have a manual so ill haft to figure it out. Thanks ronnie
You can't read your air to fuel ratio with the interceptor, you can read fuel trims though. You can't adjust the afr either with the gauge. The interceptor does read knock retard. The gauge is extremely easy to use and install, I highly recommend getting one and watching your iat2's and knock retard. Those are the 2 most important things to watch on a balt along with your afr which you would need a wideband for. 100 dollars for an interceptor is a STEAL just make sure its made for your car.
