issue running maf only
Old Sep 5, 2008 | 05:58 PM
jimbos'ss's Avatar
ok so i just got my car out of the shipment yard the other day. so i start tuning it again. seems that i keep throwing a p1101(mass air flow sensor out of self test range) up till now i didn't think there was a minimum hz that the maf had to register.
anyhow it's registering at 910hz at idle which is causing problems with my idle. right now i'm looking at either raising the dynamic airflow to just above idle again or raising the idle to the point where it generates enough airflow to hit the 1,500hz cell. the other option is reducing the maf piping size to increase the maf resolution. the only problem with that is i'm allready hitting the 9,900 hz cell at only 15 psi when i go to 20+psi i know i'll max the maf if i reduce the maf piping diameter.
i really don't wanna rely on the ve at all considering this is a turbo car, and i really don't wanna raise the idle anymore, it's allready at 900rpm's.
so..................any other ideas to solve this?
Old Sep 5, 2008 | 06:08 PM
BlackSS/SC's Avatar
Only option is to up the size the maf is in. Or if you don't have 3" pipe for a while before the maf it can cause problems. Like if it goes 2.5 and then 3" close to the maf.
Old Sep 5, 2008 | 06:24 PM
jimbos'ss's Avatar
yah i have a 3" maf pipe allready, but it's just before and after the maf, when i get the time i will be redoing all my charge piping to include the mafe pipe. i'm just wondering if the is another way that i can get the maf to read a bit higher at idle. ie hpt or something else, i really don't wanna rescale the maf though or go bigger than a 3" maf pipe just to fix an idle and cel issue.
Old Sep 5, 2008 | 06:28 PM
Z Speed's Avatar
I have my dynamic airflow set at enable at 5000 and disable at 5100 have 2 cells left to fill otherwise before I was maxing out the maf
Old Sep 5, 2008 | 06:53 PM
BlackSS/SC's Avatar
Ya it's gotta be 3" for a while before the maf and 3" after the maf to the throttle body. Other then that I don't know if there is anything else you can do.
Old Sep 8, 2008 | 10:56 AM
Rangerondubz's Avatar
What if you MAF pipe is only 2.5?
Old Sep 8, 2008 | 03:09 PM
BlackSS/SC's Avatar
You will max out the maf very easily.
Old Sep 9, 2008 | 07:32 AM
Just as I figured
Old Sep 13, 2008 | 01:49 AM
Kennyspec's Avatar
I got that same code tonight.....car was running great untill now....sputtered like hell on a 3rd gear pull. then threw the code.
Builttss
Oct 4, 2015 10:21 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
jrocstar
Sep 26, 2015 11:42 PM
jmelton327
Sep 26, 2015 10:04 PM
