LTFT and STFT
Old Jul 16, 2008 | 12:53 PM
umrdyldo's Avatar
LTFT and STFT
I know some people and companies have tuned with LTFT and STFT. ( Short and Long Term Fuel Trim)
I have a dashHawk that reads these as well. Can someone explain how these numbers work as far as lean and rich? Also, what values are good and bad?
Old Jul 16, 2008 | 03:25 PM
foff667's Avatar
positive trims mean the pcm is having to add fuel to get you back to stoich, negative trims mean the opposite.
Old Jul 17, 2008 | 04:29 PM
umrdyldo's Avatar
So as long as it's not like more than 10% the engine is probably doing well. Right?
Old Jul 17, 2008 | 04:34 PM
originaladrian's Avatar
arrggg u should use clear titles without abbreviation.
Old Jul 17, 2008 | 05:34 PM
umrdyldo's Avatar
Well when I post LTFT and STFT in the tuning section I want real responses. Those who know what those abreviations are will answer my question. Sorry to ruin your day
Old Jul 17, 2008 | 06:00 PM
Area47's Avatar
Rent me! per hour
winna winna
trims are there for a reason. you don't have a speed density car, so this is the maf doin it's job
Old Jul 18, 2008 | 09:59 PM
06SS/SC STAGE2's Avatar
If its +/- 10% thats a lot of fuel it is adding or subtracting. STFT is what the ecu is doing that instant. If any tuning is to be done based off of trims its the LTFT. Have done plenty of tuning on both of my GTO's and Mustang by making adjustments to the LTFT, all with great results. Increased MPG and HP.
Old Jul 24, 2008 | 08:48 PM
Greased's Avatar
qft. if your LTFT is varying by 10% something is up
Old Jul 24, 2008 | 09:25 PM
outtamymind's Avatar
you want your LTFT as close to 0% as possible. right now mine is sitting at -10% with a 2.80g/s on the maf and a misfire on the #2 piston probably all related to the same issue.
Old Jul 24, 2008 | 10:40 PM
rrutter81's Avatar
when i got to florida from Atlanta my LTFT went from 0 throughout the band to -8 to -12 throughout the band.....
Figured more air/oxygen in less volume = less fuel during ignition WTF?
CudaJoe
Jul 28, 2010 11:38 AM
09CobaltSS1
Jan 21, 2010 09:35 AM
Kaisoboy
Tuning
Jan 1, 2008 01:18 PM
