Maf histograms help
Maf histograms help
I am trying to maf only tune my sssc Tvs swap and am having issues getting the maf histo set up I have the aem WB set up through the ac I have searched and tried a days worth of posts any help would be appreciated.
pid
The aem Wb is working and is about .1-.2 off i can dial that in a little better I am Lost when it comes to the function string etc and the parameters for the maf histogram
Then your % error function is:
100*([USER.What ever yours is]-[SENS.121])/[SENS.121]
... or is that not the histo you need?..lol
1- Dont delete the " <> " in the strings function just insert the custom pid's in there " otherwise you will get an unknown parameter error sometimes and you'll have a wtf face on lol !
2- Make sure you add " AC Pressure " to your pid list then create the custom pid and insert it
once ur pid is dialed in perfectly, open up the the histogram called MAF AFR Error Or VE AFR Error & change the sensors or pids to the custom ones you created !
1st post & post number 5 are the most important on the corvetteforums thread !
Please read them thouroghly and Im pretty sure it'll answer most of your questions
Connecting wideband via EGR or A/C Pressure in HP Tuners - Corvette Forum
Thank you I got it
YEAH I woke up on the right side of the bed and am now tuning the maf
I was not changing the string to include the newly set up wb DUH on my part now I will dial it in then timing and Ve tuning in a week or 2 after the girlfriend calms down from me being so obsessed LOL
hey np man...when you to post a reply, just choose advanced and there's a button called manage attachements, click on that and try to upload, if it didnt accept it just " compress the files into a zip files then attach, " an alternative would be uploading the files to file hosting service and sharing the links on here...
4th pull cfg file
Tune in progress this is the tune mid maf tune any input on whats next ?? I am also concerned about the kr upon decel and at the base of the wot run screen shotts the log file is invalid
just a quick question what did you disable before tuning the MAF and what are your mods btw ?
use this website to upload your current tune and log files and give post the direct links on here...
Free File Hosting Made Simple - MediaFire
tune file and recent log
This is the tune file and log from the car yesterday My mods are k&n intake , meth , 60lb inj , tvs 2.9" pulley , cti header and dp 3" with high flow cat , stock cat back with dynomax muffler ,front mount he
graph
4thpull.hpl
tune
TVS BASE 60lb.hpt
graph
4thpull.hpl
tune
TVS BASE 60lb.hpt
