need advice with throttle body scaling
Old Mar 31, 2014 | 08:29 AM
i944scania's Avatar
Does anyone know the correct numbers for throttle body scaling on an lsj turbo with lsj throttle body? Can't quite get it right and the throws tb code, also throws a misfire code with this.
I'm also struggling with lean/rich condition occationally due to my rear o2 gone. I am not throwing any code because of this but my. Afrs go a little crazy sometimes. Would reconnecting the o2 outside of the pipe help this issue?
Old Apr 1, 2014 | 08:40 AM
05g5's Avatar
the o2 sensor AFTER that cat converter? if so that does nothing except tell you if the cat is working properly. if its the bank 1 sensor 1 o2 sensor ( the one in the manifold ) replace it......
Old Apr 3, 2014 | 04:33 PM
i944scania's Avatar
I understand what each of the o2 sensors do. But people on here are saying completely disconnecting the rear o2 causes the car to run lean, rich test occationally at idle or cruising. And that seems to be exactly what's happening.
But I really need advice with throttle body scaling numbers!
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
