PE EQ question
PE EQ question
Since my last question wasnt really pertinent and I was doing well enough already ill hopefully get an answer on this one.
I was looking at my eq Ratio and for some reason (this is stock) I see from the 3000-4000 rpm band PE commands 13.5 - 13ish AFR during WOT which seems awfully lean to me. Is there another variable im not considering?
Just curious what everyone's eq ratio was around and why.
i believe thats where mine was even set at with stage 2 at 3000-4000, the enrichment is still ramping up. There may be other enrichment variables like Cat over-temp that may help richen it when needed, but otherwise thats pretty standard, i believe it only matters around 5000-7000 where it needs to get into good richness to help reduce knock, stage 2 still only commanded around 12-12.5 AFR for some reason though.
So if my log shows im commanding 12.3 id get something like 11.1 actual.
Lowest commanded on my logs was
11.0 AFR during WOT
4771 RPM
100 MPH
IAT2 144
IAT 91
YET!!!!
12.61 is what the EQ ratio comes up with commanded PE
Why did my PCM command 11.0 when PE ratio states it is 12.61?
*scratches head
1.13672 - 1000 RPM
1.13672 - 2000 RPM
1.13672 - 3000 RPM
1.08789 - 4000 RPM
1.10449 - 5000 RPM
1.17285 - 6000 RPM
1.14160 - 7000 RPM
1.11719 - 8000 RPM
bump for avg eq ratio map
You shouldn't NEED piston protection in most cases. But it's just a safety thing to dump fuel in when it thinks there might be a danger. It doesn't guarantee anything, but it does have it's effects.
If i set it to 4,000 during my spirited runs it will kick in and destroy my spirited "performance"
however if i take it off and get the performance, something "could" go wrong and screw up #4 like IATs being through the roof @ high rpms.
There a way to modify piston protection to dump 1/2 the fuel it usually does?
Thanks for the answers btw.
edit:
n/m ill just tune my eq ratio to compensate for the protection.
gah i hate when i get to this safety vs performance crap in a non-linear fashion.
edit:
edit:
Can someone give me an example of their PE eq/ratio. I dont understand why there is a wobble curve during enrichment on the stock scan.
doesnt make sense. Would it be safe just to do a straight line up to commanding 11ish AFR?
yes it would be safe to do that and disable piston protection and COT, IF you have your MAF and VE tuned to actually get the commanded afr. I run a ramp in on PE from 12.5 down to 11.4 with no adders. been doing this for about a year now without any problems. IMO the PP and COT just throw inconsistency into the mix and screw up my method of detecting fueling errors.
the COT and PP add to the current PE multiplier table. these adders are not consistent and can add different amounts to the PE table depending on rpm, catalytic converter temperature, etc. this is why the stock PE table is not linear.
Russ's modded s2 tune
Mind checking on this to make sure nothing is out of whack?
Problem with the tune prior with COT and Piston Protect "enabled" was
RPM Commanded Actual <----reference
3400 , 13.6 , 12.27
3800 , 13.6 , 12.11
4000 , 13.4 , 11.02
4500 , 11.2 , 8.79
5000 , 10.9 , 8.82
was making me
3400 , 13.6 , 12.27
3800 , 13.6 , 12.11
4000 , 13.4 , 11.02
4500 , 11.2 , 8.79
5000 , 10.9 , 8.82
was making me
im at work right now and dont have hptuners on this pc. i'll look at it later tonight.
but keep this in mind... the stage 2 tune has huge MAF error. thats why it runs so damn rich. what commanded afr = is the total combination of all fueling tables and adders. this includes your PE table, COT, piston protection, etc.
in order to get rid of the discrepancies you need a wideband o2 and either log it with hptuners or somehow be able to correlate what maf readings are associated with each particular AFR reading.
this is something that cant be achieved with any canned tune, because its different for every car.
but keep this in mind... the stage 2 tune has huge MAF error. thats why it runs so damn rich. in order to get rid of the Maf error you need a wideband o2 and either log it with hptuners or somehow be able to correlate what maf readings are associated with each particular AFR reading.
trims are +3/-3
AFR reading above was a WOT pull /w COT and piston protection
Unless your saying to lean out my trims to +15 and go back to AFR (which id like to avoid)
^ edited ^
ok so you obviously have a wideband and know how to tune for errors.
have you disabled the cot and protection? do that, then dial in your PE table to the values you want to see on your wideband. then go see how far your afr is off.
no... +-3 is good for trims. leave those alone and forget your low portion of the maf (below like 6900hz)
only deal with your higher maf freq for now.
^ edited ^
I have standard version but its easy to see what im commanding vs my actual AFR when i compare the graphs.
Thanks for the pointers and all your help.
If, for some reason you feel you MUST have the protection in there, re-enable them after you get your afr dialed in and then adjust accordingly to the adders.
for now, get that **** outta there
leave it alone for now. i will look at the tune tonight.
no problem dude. just trying to help others as others helped me when i was figuring out this stuff
i also have hpt standard. looking back i wish i had spent the extra for the pro. its hard looking at log files, looking at the w/b gauge, and driving at w0t, and probably a big
Just curious. I keep both logs open during WOT and keep an eye on my AFR gauge to make sure it doesnt lean out. Pretty easy to match up the AFR with AFR commanded by looking at my RPM shifts and the slight lean spike coinciding with it.
I may upgrade later however this will get me dialed in pretty close for the time being.
