PE EQ question
Old Jul 2, 2008 | 03:41 PM
Bika's Avatar
Fail Less.
i have the innovate lc1. i cant look at 2 open logs while im driving so i hooked up a gauge to read my lc1. but yes i do have the logworks software and can read the afr graphs.
you dont have to upgrade to get your stuff tuned well. standard works just as well, and if you dont mind losing your a/c for a while, theres a how-to on logging the wideband with hpt standard using a custom PID and splicing a wire off the a/c pressure sensor.
Old Jul 2, 2008 | 03:53 PM
rrutter81's Avatar
yea i was seeing that, but for the minimal work checking the 2 logs after my drive ill just do it the rough way for now and gauge the rpms cmd afr vs actual afr. Can be tedious but there arent alot of tables to fill out
Old Jul 2, 2008 | 04:07 PM
Bika's Avatar
Fail Less.
agreed. i got dialed in pretty close using the standard hpt
Old Jul 2, 2008 | 06:27 PM
rrutter81's Avatar
Log going home
k ive enclosed the logworks log of my wideband as well as the hpl scan on my way home from work today. I did some WOT pulls when i could but most of it was being stuck in rush hour.
From what i see the wideband's time is about 2 seconds slower than the scan's
I turned of COT before i left work, piston protection is off.
My wideband may be off around .7 since the average ratio was 14.0 instead of 14.7
Temperature was 97 degrees
still running rich as ****
and here are the references so no one has to do the math
RPM | CMD | AFR | HZ
3250 | 12.40 | 10.95 | 7092
3500 | 12.40 | 10.22 | 7352
3750 | 12.30 | 10.26 | 7575
3948 | 11.70 | 09.75 | 7751
4250 | 12.10 | 10.78 | 7936
4500 | 11.90 | 10.14 | 8130
4750 | 11.80 | 09.75 | 8333
5000 | 11.70 | 09.50 | 8547
5250 | 11.50 | 09.48 | 8695
5500 | 11.40 | 09.35 | 8771
5750 | 11.40 | 09.30 | 8928
Hz=maf frequency
CMD = Afr commanded
AFR = Afr actual (may be off 0.7)
RPM....k yea
Old Jul 2, 2008 | 08:28 PM
Bika's Avatar
Fail Less.
i can read your tune file but the link to your hplog is not working.
you have a PM.
Old Jul 2, 2008 | 10:15 PM
rrutter81's Avatar
going for a test drive right now.... be back in 20
OMFG MUCH BETTER!!!!!!
trim tuning helped alot after what u stated.
4500 RPM
CMD:11.9
AFR: 11.2
5000 RPM
CMD:11.7
AFR: 10.6
85000 hz (needs a bit more work)
5500 RPM
CMD:11.4
AFR: 10.4
88000 hz (same)
Seems to be a bell curve since i made it that way during the PE enrich. Ill make it linear
Thanks a hell of alot for this man!!! WOW.... greatly reduced the work i had to do.
k time for run #2
k 2nd run WOT results
3400 RPM
CMD: 12.40
AFR: 12.38
3500 RPM
CMD:12.40
AFR: 11.82
3750
CMD: 12.30
AFR: 12.40
4000
CMD:12.20
AFR: 11.79
4500
CMD: 12.00
AFR: 11.97
5000
CMD:11.70
AFR: 11.66
5500
CMD: 11.40
AFR: 11.67
6000
CMD: 11.30
AFR: 11.50
9174 (mental note to change)
6500
CMD: 11.10
AFR: 11.64
9345 (mental note to change)
Pretty close for WOT runs.... just need some more work on it
Thanks a mill bika for the tips man, made my life a hell of alot easier.
Old Jul 2, 2008 | 10:30 PM
Bika's Avatar
Fail Less.
you're welcome *takes a bow*
told you 11.5 would be teh secks
command 11.4 from like 5500 on up, dial the maf in, and enjoy the ride
Old Jul 2, 2008 | 10:34 PM
rrutter81's Avatar
yea took my wife for a ride and she about **** a brick....
in fact,
she laid the seat down afterward so she didnt have to see how blurry the road was when i did a WOT run on the interstate.
weeEEeeeEEe i have a new car again!
I cant tell you how greatful i am!
Wow.... awesomeness
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
