Reading WB02 with HPT Standard, using AC Pressure Switch
Old Aug 31, 2009 | 09:42 PM
WickedSS2005's Avatar
There used to be a how-to here....but it's no where to be found (I had it bookmarked). I'm finally hooking it up. My LC-1 too a **** on me this past spring so I picked up an AEM UEGO
I followed the how-to here: http://www.hptuners.com/forum/showpo...97&postcount=5
Only I tapped the AC Pressure Switch instead of the pin-out idea like I've seen on a few others that have done this. I can't get the scanner to read. This is the function string I'm using: ([PID.7101]/(5/8.5))+10
The 8.5 is the range I got from the AEM UEGO manual, 10.0-18.5 is the digital readout range.
So, any ideas? Does the cobalt have a different code for the pressure switch?
Old Sep 1, 2009 | 10:54 AM
No one remembers the thread from about 2 years ago? Yeah, I was dumb and bought HPT standard. Meh. I know this works, just need a little help trouble shooting. I'm not sure I have the right function string or settings for the PID
Old Sep 1, 2009 | 10:55 AM
06_SIC_SS's Avatar
way to go tom! way to go!
Old Sep 1, 2009 | 12:50 PM
383_Stroker's Avatar
I remember the thread..lol.. but I cant find it.. sorry bud :-\
Is 8.5 the range, or the minimum value?
thats a short range..LOL
FYI: My Formula for my Uego is [aux..whateva]/.5 + 10 (actually i put it to 9.8 because it was off a little)
Last edited by 383_Stroker; Sep 1, 2009 at 12:50 PM. Reason: Automerged Doublepost
Old Sep 1, 2009 | 04:17 PM
I changed the formula to the "original" /.5 instead of the range of 8.5 but no luck. Guess I need to tear thru it and re-try.
Any input from anyone? The original thread from 2 yrs ago got deleted
Old Sep 1, 2009 | 09:05 PM
Are your getting a signal, and it's giving bad AFRs or no signal at all?
Old Sep 1, 2009 | 09:29 PM
Darkmanx's Avatar
There should be a thread on hptuners from from no remorse about it.
Old Sep 1, 2009 | 09:33 PM
BriantheLion26's Avatar
If you got it working before with the LC-1, make sure you change the input to read the AEM, I think, I'm used to the Pro version and I know you have to do that for it.
Just watch the gauge and adjust the maf table from it.
I have the pro version and do that half the time because if you have the WB hooked to the gauge you can't log it into HPT at the same time or it screws up the signal (LC-1).
Old Sep 1, 2009 | 10:10 PM
The LC-1 had it's own program that I used. I'll check for a post by no remorse on hptforums. Thanks Dark
Old Sep 2, 2009 | 07:01 AM
Oh you used Logwerks. Gotcha. I still think it would be just as easy to watch the gauge.
It is nice having the pro version though.
Old Sep 2, 2009 | 07:19 AM
jimbos'ss's Avatar
it was either denny or zinner that made the thread on here, i wanna say zinner did. search by his name.
Old Sep 2, 2009 | 03:00 PM
You forgot to read where the link is dead lol. No thread. Searched it all, manually and with the search. There are a TON of threads for "wideband".
I think I figured it out. I need to log the AC sensor and didn't have it set up to do that. So I'll check back tonight and then post up my work w/ pics for everyong with HPTstandard
Old Oct 12, 2009 | 08:52 PM
all4glh's Avatar
Anything ever come of this?
Old Jan 3, 2010 | 05:10 PM
damien's Avatar
Wicked, do you have any pics of how you set it up with the sensor?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Adecker
Oct 20, 2015 09:46 PM
no_ss
Oct 18, 2015 11:58 PM
dennis69
Sep 28, 2015 02:16 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
