The REAL How To: tuning VE (L61/LAP/LE5)
Old 08-20-2015, 11:21 PM
Jesse's Avatar
Warning: This is for the bluecat tool, and not the HPT VVE editor. I don't have access to the editor in the 2.25 beta. You can download the bluecat tool here:EQ <> VE Version 4 ALSO!!! This tutorial is meant for someone who is competent enough to tune. If you don't know how to disable DFCO or closed loop, or make a custom PID, this is not for you. You need to learn MAF tuning first and you can apply that knowledge here. Search the HPT forums for a MAF tuning setup. This also assumes you are using a wideband. If you aren't then shame on you I can't help with that.
So first thing's first. You need to disable your O2 sensor by disabling closed loop in your tune, and also turn off all the other crap like you did with your MAF tune. Next you need to make your custom PID for your VE airflow. You will use the same AFR error PID as your MAF tune, the only difference is that it will be based off rpm/MAP instead of MAF Hz. ALSO use the LS2 VE table. Other tables will give you negative VE numbers in high rpms. You also need to make sure your log labels and the VE editor labels match for obvious reasons.
IN THE VCM SCANNER:
STEP 2:
Go log like you normally would.
Step 3: Get your current VE table
Now that you have error data, you'll need to edit your tune just like you did when MAF tuning. First we figure out your current VE table in GMVE:
Here is your stock VE table:
Step 4: Introduce your VE error
Step 5: Generate your new table
Step 6: Paste new equations into HPT
Old 08-21-2015, 06:02 AM
I was hoping youd go a TAD bit more into detail but i appreciate the effort. I will thoroughly read this later.
Old 08-21-2015, 12:48 PM
Jesse's Avatar
What kind of detail? I can add stuff to a certain extent.
Old 08-21-2015, 02:18 PM
southal cobalt's Avatar
ive never had to use bluecat's software because I have an lsj, but I have downloaded it and played around with it. definitely a must have if you've got to tune the multi-table ve
Old 08-21-2015, 10:29 PM
Whats different about lsj ve?
Old 08-21-2015, 10:36 PM
Just read it now it seems more simple than i had thought. Nice work
Old 08-21-2015, 11:52 PM
Jesse's Avatar
It's literally a simple table you can change with a couple clicks. Much less work and no dealing with coefficients. The beta 2.25 of HP Tuners has that functionality now too, and apparently it works completely now. This is the LSJ VE:
Old 08-22-2015, 12:28 AM
Ah so its an actual ve table lol
Old 08-22-2015, 12:33 AM
Jesse's Avatar
Yep. Just like LS1s except with GMVE instead of VE %. I wish I could use HPT now but every time I try to edit any tables the editor crashes.
Supercharged06SS
12-11-2022 04:47 PM
01-12-2016 12:01 AM
no_ss
10-18-2015 11:58 PM
10-13-2015 09:32 PM
09-27-2015 08:53 PM
Quick Reply: The REAL How To: tuning VE (L61/LAP/LE5)
