Stge 2 To 2.9 pulley?
Old Apr 28, 2009 | 10:34 PM
CobaltSSilver's Avatar
I have GM Stage 2 with nate's 2.9 pulley, I did put one range colder spark plugs. Running about 20K miles now with no issues. I have an H/E I haven't installed yet, one question is do I have enough with the 1 range colder plugs for a cooling mod to be out of trouble? I am also in Denver so the elevation equals less air so I think I am okay...I.E not running too lean. Any thoughts?
Old Apr 29, 2009 | 12:27 AM
SmokinSS's Avatar
do you have A/C with stage 3
Old Apr 29, 2009 | 12:30 AM
G85 SS's Avatar
Well, I could be mistaken but I believe most GM Stage 2 tunes on a 2.9 will yield close to the same IDC's. I'm sure elevation will cause some change, not sure of how much.
I have the 2 step colder plugs + heat exchanger. For every day driving(as long as you aren't whomping up on your car) you should be fine with just the heat exchanger. However, if you are a track person, more cooling mods will be good to think about. Guys I was running with this past weekend saw IAT2 temps in the 170's with dual pass cooling. Others with dual pass plus a heat exchanger were mid 140's. Which is still high.
No. A/C goes bye bye with GM Stage 3. Plus, GM Stage 3 is a waste IMO. A guy that went to the track with us Sunday has GM Stage 3 with a 50 shot and he ran a 13.5. I ran a 13.7 with GM Stage 2 on a 2.9. No spray. I would stay away from GM Stage 3. Talk with the guys over at OTT. they offer a great stage kit that makes decent power at a really good price.
Old Apr 29, 2009 | 07:55 AM
That is good to know, I don't want to run too lean or too hot. I have contemplated running the Cobalt Addicton 2.8 but I keep hearing how it will run too lean and create too much heat without at least a Dual Pass and HE
Old Apr 29, 2009 | 02:56 PM
G85 SS's Avatar
Well the M62 does nothing but create a lot of heat. Cooling mods should not be overlooked by any means. They are going to be better for your car, whether you run the GM Stage 2 Pulley or get all crazy and run a 2.5.
Old Apr 29, 2009 | 03:32 PM
ddsscobalt's Avatar
i have gms2 and i see about 15-16 at rpms above 5500k... i ordered nates 2.95 to be safe until i can afford the ottp kit.. im hoping for 17psi and a little lower end pull
Old Apr 30, 2009 | 08:24 PM
hawkeyez's Avatar
My ZZP Heat Exchanger and my 2.9 pulley came yesterday and will be installed tommorow. Cant wait. HE looks sick with ZZP stamped in red on the front. It will match my car.
Old Apr 30, 2009 | 11:06 PM
ddsscobalt's Avatar
Well i installed the nates 2.9 today... and im very proud of myself.. first time i took the entire s/c off the car.. i was a little nervous and all being 19 and just ripping it all apart.. nothing like doing an audi turbo haha.. i got it all done, and i did some runs.. it gives more boost at the lower rpms, but i didnt go past 15-16 psi at all at wot.. i was hoping for 17 :'(
Old May 1, 2009 | 12:09 AM
InfraRedline's Avatar
Dont feel bad man. I only hit 16 with my 2.9 when I had cat back only. Now with header, dp, and my cutout open i hit 15 usually. Maybe 16 on a good day.
Old May 1, 2009 | 08:59 AM
It just seems to raise the TQ all acroos the RPM range is what I noticed and I did feel a bigger kick in the pants on the top end too. If you don't have it add a CAI and catback you won't be dissapointed in the car.
Old May 1, 2009 | 12:16 PM
  #36
ddsscobalt's Avatar
i have all of that already.. haha i did notice a difference, but i just wanted a little smirk seeing 17 psi lol
Old May 1, 2009 | 12:19 PM
  #37
I feel ya....at the end of the day it is all about how fast the car runs anyway. shoot how many dyno queen cars are out there that can get smoked on a road coarse or drag strip because they make better use of power or have a better power curve.
Old May 1, 2009 | 12:37 PM
  #38
hawkeyez's Avatar
My 2.9 pulley and heat exchanger get installed today.
Old May 1, 2009 | 02:15 PM
  #39
rcorona8's Avatar
Do i need to remove my supercharger to remove my stage 2 pulley and install a 2.9 pulley?
Old May 1, 2009 | 03:16 PM
  #40
it makes it MUCH easier! It only takes about 5 mins to get the blower off
Old May 1, 2009 | 05:05 PM
  #41
rnjmur's Avatar
No. It a little easier to work with the blower off the car, but not necessary. Make sure you break the bolts loose BEFORE you take the belt off or it will be a bitch getting them loose unless you have someone to help you.
Also, the bolts should only be torqued to 15 pounds I believe. Don't over tighten them or you will have a bitch of a time ever getting them back off. Also don't use any thread sealer on the pulley bolts or you will have a bitch of a time getting them back out again.
Old May 1, 2009 | 05:41 PM
  #42
hawkeyez's Avatar
my parts will now be installed tommorow cant wait.
Old May 1, 2009 | 05:43 PM
  #43
ddsscobalt's Avatar
i had to take my blower off and use a 3/8 impact on super low setting to get the stage 2 bolts off.. it made it so easy with that.. and then i just blipped the new stainless cap screws on and tightened with my hand holding the pulley and an allen key... i was nervous taking the charger off, but now i feel like i could do it in 5 minutes since i realized how easy it is
Old May 2, 2009 | 12:00 AM
  #44
rnjmur's Avatar
Yeah, if you had the stage 2 installed then the tech MAY have torqued the screws down as hard as he could. If so, you will have to take the SC off to get the bolts loose.
Old May 2, 2009 | 03:38 PM
  #45
that and the tech shoudl've used locktite for the stage 2 pulley. I had the same Chevy dealer install my 2.9 because I couldn't get the GM pulley off, they said 'we used a lot of locktite and had to drill the bolts out' LoL
I said to them no wonder I couldn't get it off without feeling like I was going to break something.
Old May 3, 2009 | 12:52 PM
  #46
hawkeyez's Avatar
My 2.9 pulley and ZZP heat exchanger are installed and wow what a difference. I love it.
Old May 3, 2009 | 04:29 PM
  #47
How was the HE install? How long did it take and do you have the Option B surge tank from GM to purge it properly?
Old May 5, 2009 | 04:02 PM
  #48
hawkeyez's Avatar
The Heat exchanger was not that hard to install it is a direct bolt on. The only hard part was getting the bottom hoses off just because they did not want to come off there was like something sticky on the inside of them. Thats GM for ya. I will look into the Option B. I do have fluid drip out of the overflow but I dont know if thats normal??
Old May 5, 2009 | 05:32 PM
  #49
rnjmur's Avatar
Yeah, GM put glue on the hoses for the IC system. Quite a pain in the ass. When I did my dual pass with option B the hardest part of the install was getting the hoses off.
Old May 5, 2009 | 05:46 PM
  #50
What did you guys do when putting it back on? Did you use some glue as well to keep from leaking?
