temporary wideband install
Old Sep 18, 2008 | 07:39 PM
BeermanSSSC's Avatar
I haven't been able to find enough information that I'm looking for. I'm just learning to tune and I want to keep doing it more. I have been learning through books and on my own car. I have someone who wants me to do some tuning on their car. My car has a lc-1 permanently installed. His does not have a wideband. I want to get the new LM-2 to work on other peoples cars. I am trying to find out how a temporary install would work. I know on a non-cat car you can attach the sensor to the tailpipe. What about on a car that still has catalytic converters? How can I temporarly install my wb on someone elses car to tune it?
bump????
Last edited by BeermanSSSC; Sep 18, 2008 at 07:39 PM. Reason: Automerged Doublepost
Old Sep 18, 2008 | 07:44 PM
Bl4des's Avatar
you should be able to take the rear o2 sensor out but it might be to far down the exhaust
Old Sep 18, 2008 | 07:46 PM
yeah thats what i thought, but i think the cats would cause false lean readings. anyone confirm this????
Old Sep 18, 2008 | 07:51 PM
Bl4des's Avatar
no it wont the rear o2 sensor is just there to make sue the cat it working right you can take it out you can also just disable it using hp tuner
Old Sep 18, 2008 | 07:54 PM
will that change the fueling though? If the engine is monitoring o2 sensors to adjust fueling, would disabling the rear's change this?
Old Sep 18, 2008 | 07:55 PM
Bl4des's Avatar
no it uses the front o2 sensor to monitor the air fuel ratio not the rear one
Old Sep 18, 2008 | 08:01 PM
ah right, i got ya. thanks for you help man. then would it be possible to just put it on a pipe clamp at the tailpipe like you would on a non-catted car?
Old Sep 18, 2008 | 08:04 PM
Bl4des's Avatar
it dont think it should be mounted right after the cat just disable the rear o2 sensor and just put it there
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
