Universal Injector spreadsheet
http://www.thetuningdoctor.com/Excel...orscalels2.xls
I had some down time last night that I got to use constructively...using the origonal spreadsheet made by an unknown author(thank you whomever you are) I modified it to work with not only LS1's, but all GTO's, all cobalt SS's, and many if not most late model ie 97+ GM V6's.
Have fun.
Bill
Have fun.
Bill
eck...i think I copied the wrong one over for you guys...I'll get it fixed asap.
should be fixed now, same link.
i dont know what numbers where there before but i used what ever they where i have the hp tuners out out for both if you do it in reverse. but i did put it in my comouter and for the most part it work great !!! alot faster then the flow i had before.
when i put 60 in the injector flow rate here what i get
7.698272057 7.780348516 7.861568126 7.955276372 8.034727906 8.113401438 8.191319384 8.281297122 8.357649932 8.433311494 8.508300249 8.594960261 8.668550758 8.741521756 8.813888641 8.897572801 8.968680623 9.039229086 9.109231188 9.190226418 9.259086995 9.327439217 9.406555751 9.47384407 9.54065783 9.607006933 9.683839681 9.749214396 9.814153641 9.878666006 9.953401972 10.01701758 10.08023172
All those 8.00 and up max the injectors at like 64.39 so tell me what u get when u put that stuff in
Last edited by NightriderCobaltSS; Mar 4, 2007 at 09:59 AM. Reason: Automerged Doublepost
6.324775889 6.392208581 6.4589373 6.53592648 6.601202576 6.665839478 6.729855604 6.803779859 6.866510093 6.92867241 6.990281958 7.061480423 7.121941187 7.181892979 7.241348442 7.310101995 7.368523032 7.42648451 7.483997105 7.550541476 7.607116213 7.663273294 7.72827416 7.783557155 7.838450261 7.892961611 7.956086155 8.009796964 8.063149998 8.116152315 8.177554176 8.229819731 8.281755448
thats with
58
58
60
entered into the sheet
if you've got injectors that are larger than 60lbers then yes you will max them out earlier.
The numbers you listed leads me to believe your using ~70lb injectors which is well over the table max.
thats with
58
58
60
thats with
58
58
60
thats with
58
58
60
58
58
60
it looks alot better Thanks your the best
Just what I needed (I think) Siemens 60lbs sitting on shelf. waiting for pulley selection and HPTuners. gotta order.
Is the fuel pressure supposed to be 58? I thought and believe so I am just confirming.
thanks
thanks
Last edited by Asphalt Assault; Mar 15, 2007 at 12:38 PM. Reason: Automerged Doublepost
http://media.gm.com/us/powertrain/en...2007/07car.htm
Sl0wbaltSS
Nov 21, 2018 11:11 PM
