Bulb out?
Hey, VisionBulbs,
I recieved my 8000K 9007 kit last friday, and installed it the same day. They worked great, and I love the way they look! Sunday though, I was driving around with some friends, and we stop by a pizza place (Imo's
) to eat, and when I come out to my car, only my driver side headlight came on.
I used the relay harness, not the plug-and-play wires, and I checked my wiring, and to see what was/wasn't getting power and all, this is what I got.
- The passenger ballast is getting power, and sending power to the bulb
- I noticed though, that it is not buzzing like it usually does, and like the one that is working
So it appears to be a problem with the bulb, I guess. What should I do about it? Should I use the plug-and-play wires? Or is the bulb toast?
Thanks for the help, and I love the way they look (when they work).
(Any help from members is also welcome)
Anthony
Order #290859484
) to eat, and when I come out to my car, only my driver side headlight came on.I used the relay harness, not the plug-and-play wires, and I checked my wiring, and to see what was/wasn't getting power and all, this is what I got.
Anthony
Order #290859484
EDIT:
Today before work, I got to messing with it again, and I switched the bulbs around. The driver side is still the one that works, soooo... ITS NOT THE BULB. I guess the ballast is broken. Anyone else have this problem? It only lasted 2 days!?!
If the ballast needs to be replaced, you can have it sent back with the following return form: http://www.visionbulbs.com/vb_product_ret.php
Thank you again
royce777
Sep 28, 2015 07:11 AM
