War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
2.4SS vs. 99-02 cav Z24
Old May 28, 2006 | 12:42 AM
Dragonsfire12345's Avatar
Well me and my friend were leaving the usual gathering spot friday night and we were rolling down the highway and we came upon a stretch of open road my friend yelled to me if I wanna run since there was no traffic and I said "sure why the hell not." So we were rolling at around 60mph and we both pretty much gunned it at the same time. we stayed dead even until 90mph and I start pulling him, not by much though then we shut off at 100. I was pretty amazed it was that close. All he has is an Intake and thats it. Anyone know how much hp and torque the 2.4 twin cam push out? Also he is auto and all my mods are in my sig.
Old May 28, 2006 | 12:47 AM
mtwal16's Avatar
wow, thats pretty impressive for the cavy. although i have a friend w/ a base cavy w/ intake/ exhaust running mid 15's in the 1/4. idk about a Z24 tho, i thought they had like 150 hp and like 155 lb tq
Old May 28, 2006 | 12:53 AM
OniMirage's Avatar
hmm ... how heavy are those konigs?
Old May 28, 2006 | 12:55 AM
on konigs website they say they only weigh 19.5lbs
Old May 28, 2006 | 01:01 AM
OniMirage's Avatar
huh strange ... well at least you didn't lose ...
Old May 28, 2006 | 01:19 AM
Well I did a little research and I found this on one site:
http://www.conceptcarz.com/vehicle/z188/default.aspx
Year 2000
Make Chevrolet
Model Cavalier Z24
Weight 2838 lbs | 1287.3 kg
Performance
0-60 mph 8.6 seconds.
Engine
Engine Configuration I
Cylinders 4
Aspiration/Induction Normal
Displacement 2.40 L | 146.4 cu in. | 2399.5 cc.
Valvetrain DOHC
Horsepower 150.00 BHP (110.4 KW) @ 5600.00 RPM
Torque 155.00 Ft-Lbs (210.2 NM) @ 4400.00 RPM
HP to Weight Ratio 18.9 LB / HP
HP / Liter 62.5 BHP / Liter
AND: http://www.conceptcarz.com/vehicle/d...ptionalEngines
Year 2006
Make Chevrolet
Model Cobalt
Engine Location Front
Drive Type Front Wheel
Weight 2780 lbs | 1261 kg
Cylinders 4
Displacement 2384.00 cc | 145.5 cu in. | 2.4 L.
Valves 16 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 171.00 BHP (125.9 KW) @ 6200.00 RPM
Torque 163.00 Ft-Lbs (221 NM) @ 5000.00 RPM
HP to Weight Ratio 16.3 LB / HP
HP / Liter 71.3 BHP / Liter
Redline 6750
Bore 3.46 in | 87.9 mm. | 0.1 m.
Stroke 3.85 in | 97.8 mm. | 0.1 m.
Compression Ratio 10.4:1
Fuel Type Gasoline - Petrol
Block Cast-iron
Head Aluminum
Old May 28, 2006 | 01:43 AM
3fo893013L's Avatar
the weight of your car gave him an upper hand in hanging with you.
Old May 28, 2006 | 01:46 AM
joedashow's Avatar
Not too sure about that; the Z24 weighs more than the SS.
Old May 28, 2006 | 11:33 AM
Tomtwtwtw's Avatar
Year 2000
Make Chevrolet
Model Cavalier Z24
Performance
Engine
Cylinders 4
Valvetrain DOHC
That has to be for an auto, the Z24 is capable of reaching 60 a second faster than that. Even if it is an auto, too, my girlfriend's auto Z24 could keep up with my Pontiac, which was about 8 flat to 60, so hrm... great info otherwise, though. The engines are closer in power output than their ratings would make them out to be, although I suspect that guy had a little more than an intake to hang with you that long. Unless of course he's got a stick, since you have an auto. The gearing of the stick would make up for some of the power difference as well. Good race.
Old May 28, 2006 | 12:47 PM
06G5GT's Avatar
Bone stock, the Z24 LD9 2.4 could run 15.8-16.0 average. Fastest bone stock was a 15.2 factory freak.
There is a noticable power difference between the 2.4 LD9 and the 2.4 VVT. My 96 Sunflower GT had a Ractive intake, high flow cat and mufflers and while those mods really woke up the highway performance, third gear still didn't pull anywhere near as hard as what my G5 does stock.
Old May 28, 2006 | 01:50 PM
snowbred's Avatar
i dont know man but i raced my share of z24s with my old 04 cav auto.. they beat me off the line but i ended up pulling on them at higher rpms.. and i was stock, dont know about the z.. race him from a stop and see who will win .. autos dont like racing from a roll specially between 50-60.
Old May 28, 2006 | 11:40 PM
he only has an intake, and he has an auto. I'll double check next time.
Old May 28, 2006 | 11:43 PM
Beck's Avatar
I raced one of these last night in my manual 2.4 i was pulling the entire time but they wernt far behind. they had exhaust and intake... so did i, but i won, still close though. it was fast enough to hang but not pull on me. i was kinda playing with her too i didnt really try my hardest, but it was still a good race
Old May 28, 2006 | 11:56 PM
charged_sunfire's Avatar
wanna race my z24? lol yeah 2.4 cavys run stock at 150hp which to the wheels is only like 130ish was what mine dyno'd at stock. i ran a 15.9 stock but with a intake you can get them into mid 15's.
Old May 29, 2006 | 12:03 AM
thanks for the info I'll have to race him from a dig and see what happens also.
Old May 29, 2006 | 10:38 AM
RaineMan's Avatar
I'm gonna be running against some Z24's this week at the strip... I'll post my slips.
Old May 29, 2006 | 05:39 PM
snowbred's Avatar
if you want to make this interesting put it in L and watch what happens lol
Old May 29, 2006 | 08:48 PM
supermantxz24's Avatar
I had an 02 z24 5 speed and ran a 15.3 (stock)with a broken motor mount and bald tires never ran it with fixed mount and tires though what do ss n/a's run?
Old May 29, 2006 | 10:30 PM
low 15's.
Old May 30, 2006 | 01:09 AM
JackD's Avatar
Ha! My girl had a late 80s Z24...
I have the 2.0 SC and she was definitely going 0-60 in some where around 7 sec...
The first time I lined up with her she warned me and told me she took it to the track once when she was 17 and wasted a riced out eclipse... made the guy pretty pissed...
Any how I underestimated it went half throttle and off the line she had me pretty good... not until about half way through second gear did I pass her...
The Z24s were worthy of that badge!
Old May 30, 2006 | 01:13 AM
JackD's Avatar
The rear wheel drive on hers seemed to have helped a ton and it was a V6 not a 4...
After that first time running her I never took it easy again but she would always have me right at first... damn wheel hop.
Old May 30, 2006 | 08:44 AM
06G5GT's Avatar
Jack, all Cavalier Z24's were FWD. And if it was a late 80's, it had the 2.8 V6 which made the car a low to mid sixteen 1/4 runner.
Old May 30, 2006 | 06:08 PM
the old ones had a totally different engine, i think 2.8 or 3.1's, we're talking 2.4 dohc (twin cam) here 96-02, the 03-05 have 2.2 eco's and the 95's had the 2.3 HO engine
Old May 30, 2006 | 09:09 PM
JackD's Avatar
It was definitely rear wheel drive man... it was OLD! It didn't share a single part with our cars like ^^^ that guy said... it was a totally different car... but I still say they were worthy of the badge Z24 just like the 2.4 ecotec is worthy of the SS badge.
They were never 'fast' cars but they would hang with the competition...
Old May 30, 2006 | 09:11 PM
JackD's Avatar
That is a fast sunfire you have man... nice work!
Is it the same Eaton that is on the LSJ?
