War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
Cobalt LT vs Rx-8
Old Oct 16, 2009 | 01:26 PM
  #51
Razor564's Avatar
No ****. Now your talking about handling which is way off base.
I've raced a 8 in a straight line. I have less hp, and more tq. I won by a ******* football field.
Old Oct 16, 2009 | 01:30 PM
  #52
SLoW SHO's Avatar
No, you won because you make more powaaaaa
If you made less powa you probably would have lost.
Old Oct 16, 2009 | 01:32 PM
  #53
Cobalt_Daddy's Avatar
Originally Posted by SLoW SHO
An rx8 with no torque murders a Mustang GT around a road course. Not only that, but they're capable of mid 14 second 1/4 mile times. I could list 10 cars off the top of my head that make TWICE the torque of an RX8 and run slower times.
Sorry I didn't realize I was dealing with people who have the thought process of a kindergardener. Those numbers were representation of peak tq with a typical power curve for those given numbers.
Car B slaughters the **** out of Car A because it makes TWICE as much POWER with FOUR TIMES less TORQUE.
Where was all the torque in that race?!?
as much as 1BADSS/SC is a postwhore **** disturber .... i am going to have to agree with him on this one with respect to the rx8 being a shitbox in the acceleration performance department... the car makes little to no torque... which is why it isn't that quick compared to alot of other cars... it makes it's power too late in the power band... and yes torque is what gets the car going... mathematically they are inversely proportional yes... .. and well the rx8 beating other cars with more torque on a road coarse has more factors involved like how heavy it is... it's weight distribution... suspension... tires... , driver skill, method of driving the axels and etc. and it murders a mustang GT because a mustang GT is a POS with a solid rear axel and handles like a sack of potatoes... there is exceptions to every statement of course and more torque than HP doesn't always mean faster and you do make some good points ... but again in the end the lack of torque is what makes that rx8 a POS in the acceleration department and any review you read on this car will state that. also keep in mind that a car with less torque could have less traction issues which means it gives it a bit of an advantage given it's disadvantage in the torque department...but again it's all relative to the application and the setup of the vehicle being used.... that being said... torque and HP are dependant on each other... you can't have one without the other... and again the ratio of HP to torque is depedant on the application intended. If they wanted the RX* to be an awesome car from every standpoint they should have found a way to produce more torque without needing the 9,000rpm redline to do it because by the time you hit that... the race is over.
  #54
twzted's Avatar
i edited my post while you wrote this...
Old Oct 16, 2009 | 01:34 PM
  #55
SLoW SHO's Avatar
The RX8 will still beat a **** load of cars with twice as much torque in a straight line.
It's possible to have a car that makes 1,000 lb/ft of tq be slower than a car that makes 100 lb/ft.
Is it possible to have a car that makes 1,000 hp be slower than a car that makes 100hp?
Old Oct 16, 2009 | 01:36 PM
  #56
brickerenator's Avatar
You are leaving out gearing, weight, suspension, and traction
Old Oct 16, 2009 | 01:37 PM
  #57
SLoW SHO's Avatar
The quote was "Horsepower sells cars, Torque wins races"
I see no mention of anything else.
Old Oct 16, 2009 | 01:40 PM
  #58
fakameanrepresent's Avatar
high revving, no torque, doo doo engine.
  #59
twzted's Avatar
you cant get that 1000hp with out torque...
Old Oct 16, 2009 | 01:44 PM
  #60
SLoW SHO's Avatar
You can't move a car without powaaaa.
If applied to bikes, Harleys would smoke liter bikes in the 1/4 mile because they have more torrrrrrrrqueeeeeeeeeeeeeee
Isn't the old value on measuring how one car will do vs another car HORSEPOWER TO WEIGHT and not tq to weight? **** if we did tq to weight a cummings turbo diesel would slaughter a Zr1!
Old Oct 16, 2009 | 01:45 PM
  #61
BlueBolt66's Avatar
The RX8 wasn't made to go fast in a straight line. I almost bought one, When I drove it didn't seem all that gutless it wasn't an auto and was actually pretty quick granted not as quick as my car. I kinda wish I woulda bought it. Very nice ride IMO.
  #62
twzted's Avatar
and how do you get power? HOW is hp made?
i told you already...
Old Oct 16, 2009 | 01:46 PM
  #63
victoryss's Avatar
thats reatarded...clearly by the calculation CAR B will have a higher HP output because of RPM......but at the same time its a terrible statement...because measuring torque at 2 different rpm pts doesn't mean ****...
what if car A can have an RPM of 10k as well what is its TQ value?
how quickly does a cars power drop off? power numbers don't mean ****...you need a whole sheet to get a better idea and thats why you have HP and TQ
if you are saying that those are MAX torque values of the car...which a car that makes max torque ***AFTER 5252 rpm is just wrong because it drops of as RPM increases...
TQ makes you go
HP keeps your going
***Torque curves and HP curse CROSS at 5252...so that means TQ has to be higher before 5252 and lower after than the HP curve
ding ding ding we have a winrar!
  #64
twzted's Avatar
TQ makes you go
HP keeps your going
so here you go since you didn't go re-read...
Old Oct 16, 2009 | 01:51 PM
  #65
SLoW SHO's Avatar
Dude no one is arguing if you can have horsepower without torque, step off the wrong soap box.
I'm arguing that the quote "Horsepower sells cars, Torque wins races" is WRONG.
Old Oct 16, 2009 | 01:53 PM
  #66
twzted's Avatar
yes you are correct here...
but again...to make power you need torque...
but then again it all goes to engine performance...how quick does the torque die off how high do you rev the engine, because i don't think harleys rev to 10-12k like a sport bike(i know nothign about bikes, but that is my assumption)
Old Oct 16, 2009 | 01:56 PM
  #67
SLoW SHO's Avatar
It's about right. Harleys make way more torque, and way less horsepower. Guess what, Harleys get smoked.
But, but but, "torque wins races".
Now who do you agree with?
Old Oct 16, 2009 | 01:59 PM
  #68
twzted's Avatar
im fighting the fact that strictly HP doesn't not win races nor does TQ...its finding the balance of them
Old Oct 16, 2009 | 02:00 PM
  #69
SLoW SHO's Avatar
So then the quote is wrong.
Thanks!
I guess we both need to keep telling ourselves that we know more than Carrol Shelby, or was it Enzo Ferarri who said it?
Bah who cares! It's wrong! ahhahaha
Old Oct 16, 2009 | 02:09 PM
  #70
Mathematically speaking neither exist without the other. You can rearrange the equation to prove that either can't exist without the other. But what it all comes down to is the other factors... what type of car it's in... if it's in a heavy car torque is the main concern to get the weight going... if it's a light car then torque isn't needed as much. either way you can make a car with less torque or more torque faster or slower than the other car by changing outside factors. it's mathematically impossible to say that one is better than the other because they again both depend on each other and are directly proportional. EG power drill... you need torque for that tight screw and can't do it with high rpm's so you adjust it with the torque settings on it which changes the gear ratios giving it an advantage... and so it's slower... but high rpms can screw something in alot faster but only if it is physically able to.... so as you can see it is dependant on the application... one can screw something in faster than the other but only if the outside factors allow the other one to do so.
Old Oct 16, 2009 | 02:10 PM
  #71
twzted's Avatar
it is a vague quote...if you could assume that every engine ran along the same consistent curve...then yes more tq would always be more HP...but they don't
Old Oct 16, 2009 | 02:11 PM
  #72
SLoW SHO's Avatar
Originally Posted by Cobalt_Daddy
Mathematically speaking neither exist without the other. You can rearrange the equation to prove that either can't exist without the other. But what it all comes down to is the other factors... what type of car it's in... if it's in a heavy car torque is the main concern to get the weight going... if it's a light car then torque isn't needed as much. either way you can make a car with less torque or more torque faster or slower than the other car by changing outside factors. it's mathematically impossible to say that one is better than the other because they again both depend on each other and are inversely proportional. EG power drill... you need torque for that tight screw and can't do it with high rpm's so you adjust it with the torque settings on it... and so it's slower... but high rpms can screw something in alot faster but only if it is physically able to.... so as you can see it is dependant on the application... one can screw something in faster than the other but only if the outside factors give the other one the advantage.
Gearing, actual force at the wheels is determined by gearing.
Old Oct 16, 2009 | 02:13 PM
  #73
twzted's Avatar
Mathematically speaking neither exist without the other. You can rearrange the equation to prove that either can't exist without the other. But what it all comes down to is the other factors... what type of car it's in... if it's in a heavy car torque is the main concern to get the weight going... if it's a light car then torque isn't needed as much. either way you can make a car with less torque or more torque faster or slower than the other car by changing outside factors. it's mathematically impossible to say that one is better than the other because they again both depend on each other and are inversely proportional. EG power drill... you need torque for that tight screw and can't do it with high rpm's so you adjust it with the torque settings on it which changes the gear ratios giving it an advantage... and so it's slower... but high rpms can screw something in alot faster but only if it is physically able to.... so as you can see it is dependant on the application... one can screw something in faster than the other but only if the outside factors allow the other one to do so.
true you can...but you can not measure HP with out torque since HP is power...you need a measure of work(TQ) work involves a measure of force
Old Oct 16, 2009 | 02:14 PM
  #74
SLoW SHO's Avatar
You mean more horsepower would always beat more torque?
Two cars, geared appriopriately, same weight, same consistant curves reletive to their power.
Car A: 200hp 400tq
Car B: 400hp 200tq
Car B is making twice as much power, with half the tq. It's going to murder car A.
  #75
Wink
so you are saying my lawnmower can make more power to the wheels than my cobalt SS if i gear it right? lol
