versus CLK Kompressor
So was coming back from the store and ran into a Mercedes CLK (not sure which CLK) but I did see "Kompressor" on the side. We toyed around a bit for two lights, then we finally went at it. I thought it'd put up more of a fight than it did. At about 15 over the limit, I let off and was already a car length ahead. I don't know Mercedes enough to tell which one it was, but I'm doing some looking. It may have been an early 2000 type model, 2001, or 02'ish, but I'm not really sure. I'm going to try to do some looking to find out.
At anyrate, to make himself feel better, he had to continue on and then get in my lane after I let off
Mercedes has never made a CLK "Kompressor" , not North America anyway - they've always been N/A (older models had a 3.2L V6, 4.3L or 5.0L V8. AMG versions had a 5.4L V8. New models have a 3.5L V6 or a 6.3L V8 in the AMG) Sounds like someone stuck a badge on a regular CLK, but I guess as he found out, badges don't really add horsepower *L*.
You sure about that? I'm pretty certain you use to be able to get a CLK with the Kompressor. They had those two door hatch looking cars for awhile, and I know I raced one of those that had Kompressor on it, and I've seen a few of them around, all having Kompressor on them.
CLK...
C Coupe "Kompressor"..
What you raced was an SLK230 Kompressor:
From MSN Autos:
Mercedes-Benz SLK 230 Kompressor - 2.3L supercharged (5A + ABS)
0 - 60 Time-7.28
1/4 Mile Time-15.55
1/4 Mile Speed-92.00
..............................SLK230.............. SLK320...............SLK32 AMG
Standard Engine: 2.3L 192 hp I4.....3.2L 215 hp V6.....3.2L 349 hp V6
Horsepower: 192 @ 5300 RPM.....215 @ 5700 RPM.....349 @ 6100 RPM
Torque (lb-ft): 200 @ 2500 RPM.....229 @ 3000 RPM.....332 @ 4400 RPM
From MSN Autos:
0 - 60 Time-7.28
1/4 Mile Time-15.55
From MSN Autos:
0 - 60 Time-7.28
1/4 Mile Time-15.55
From MSN Autos:
0 - 60 Time-7.28
1/4 Mile Time-15.55
From MSN Autos:
0 - 60 Time-7.28
1/4 Mile Time-15.55
From MSN Autos:
0 - 60 Time-7.28
1/4 Mile Time-15.55
Eh, I could have taken eitehr the SLK230 or 320. Is the 230 still produced?
As for the M62, that's ok, I'm sitting on an M90. I thought I read somewhere that Mercedes uses some type of odd snout or clutch for their blowers so you can't swap pulleys and get the same results as we do.
That's not it. The back end was slightly bigger, in addition, it's not nearly as squared off. That's far too new of a car. It was an older model merc. It was an SLK, just not sure which SLK due to not knowing the year.
kind of a neat idea, toyota used to do something like that on the blown MR2s.
Re the S/C's, yes they have have a magnetic clutch setup, but pulley swaps are still a popular mod even so.
P.S. Neither the SLK230, nor the C-coupe are currently produced.
soundjunky
Aug 28, 2015 03:24 PM
. C-coupes have never been available as ragtops
