¿Spacer Question?
Old Feb 26, 2012 | 08:46 PM
MastaShaKe_88's Avatar
¿Spacer Question?
Hey my rims have like 1mm of clearance from my Brembos, so I went an got some spacers from Autozone.. These --> Dorman/AutoGrade 2 pcs. 5/16 in. thick 4 1/2 - 5 1/2 in. bolt circle 5 lug wheel spacer (711-914) | Disc Brake Wheel Spacer | AutoZone.com
They're 5/16" or 7.9mm an they're 'universal', I put it on one rim a lil earlier jus to see if it'll fit, an it does.. but has any1 ever messed with these? Any Pro/Cons? They didn't seem to solid on the lugs, like cuz of the holes it can jus shift left an right an i move it a lil.. I put the rim on an it seemed solid, but I can see it when I'm standin nex to my car
anybody with some spacers got somethin better? Or are they all kinda like this??
Old Feb 26, 2012 | 08:50 PM
JB909's Avatar
i got some the same size off ebay, their steel. i didnt have any problems with them i just got open end lugs so they would def tighten down. Had em on for probably 20k miles
Old Feb 26, 2012 | 08:56 PM
Maupin SS/SC's Avatar
I think will had some universals in the rear. i had 5mm h&r ones made for saabs. same exact thing. the H&R's were top notch
Old Feb 26, 2012 | 09:10 PM
Maven's Avatar
no reason to get 5/16" spacers. get some 3mm(1/8") ones and youll have plenty of room.
Old Feb 27, 2012 | 01:05 AM
I got those cuz otherwise I'd have to order somethin an wait for it to come in..all the local stores got the same thing/size.. these make my wheels up front poke out 2 much tho, like if I keep these, id go an get some more for the back jus to line em up
Would I be good at this depth tho? In terms of driveability, stability an all that good ****?? Or should I jus learn some patience an order some slimmer ones?
Old Feb 27, 2012 | 01:14 AM
devilbmxer120's Avatar
I hope you have extended studs for that thickness... I barely feel comfortable running my 5mm ones on stock studs. I had universal ones but i ended up cracking one in half and breaking a stud too. I just waited and spent the extra $ on some from CED. Just my 2cents masta
Old Feb 27, 2012 | 08:27 AM
Frogstofall's Avatar
If you want the best quality and SAFETY, get custom made hub-centric spacers. I actually have a spare set of 5mm thick hub centric ones that were too thin for my application. If the wheel you have has a 73mm bore, I would sell them to you cheap.
If you need another bore size, check out Motorsport-tech.com. They are pretty legit and mine are top quality. Don't mess around with cheap-o AutoZone crap or generic spacers. They will vibrate to no end at high speeds and will crack as someone else has already experienced.
Edit: Pic of my spacers...
Old Feb 27, 2012 | 09:06 AM
i (lsj though) got mine from crateenginedepot.com they were drilled out perfectly to fit smooth on ur hub and lugs. i think 5mm just enough to make a difference, but thats all our stock lugs can handle.
Old Feb 27, 2012 | 09:08 AM
5mm is max for stock wheel studs.
Got a pic of the CED ones?
Old Feb 27, 2012 | 10:44 AM
My hub is 65.1
I ended up jumpin on these cuz most of the ones I saw were universal anyway, so I was all like.. meh..
The ones I got were 7.92mm so damn I shouldn't even drive it around yet huh? Lol it did tighten down.. but not really like I wanted
Old Feb 27, 2012 | 11:01 AM
Yeah, the hub of the car is 65.1, I'm talking about the center bore of the wheel.
Definitely don't ride around on those spacers without longer wheel studs!!!
Old Feb 27, 2012 | 01:08 PM
i dunno >.<
Old Feb 27, 2012 | 06:19 PM
Maven's Avatar
Just get some 3mm ones.
Old Feb 27, 2012 | 09:41 PM
im bout to order some
Old Feb 27, 2012 | 09:50 PM
Whining-devil's Avatar
get the ones from ced, or powell
Old Feb 27, 2012 | 10:08 PM
jus ordered some 5mm ones.. I wanna be able to put my center cap on says it should be in Friday
Old Mar 20, 2012 | 07:38 AM
sS07NA's Avatar
Found some 5mm for a good price but my question is do they need to be hub-centric since there so small and the wheel is still on the hub??
Old Mar 20, 2012 | 05:17 PM
dont have to be, but id still get some that are.
Old Mar 20, 2012 | 10:47 PM
rcsrracing15's Avatar
what would be a good offset for alittle poke on the tc rims? i was thinking 15mm?
Old Mar 20, 2012 | 11:52 PM
sounds about right. hope you have extended studs :p lol
Old Mar 21, 2012 | 12:17 AM
1LoudAssChevy's Avatar
just put on 10mm universal spacers all around + i replaced all my studs with extended studs(blackworks retrofit lmao) no problems as of yet
Old Mar 21, 2012 | 12:18 AM
those tc rims are 18 by what(18x7.5)??? if so i would so a 15mm like youre thinking
Old Mar 21, 2012 | 12:25 AM
yea t/c wheels are 18x 7.5. s/c are 18x7.0
Old Mar 21, 2012 | 12:27 AM
yea 15mm...might have to roll the fender a little more than it already is but it would look cool
Old Mar 21, 2012 | 05:50 AM
ok sweet lol so 15mm and extended studs? thats wont give me any problems?
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
goaliemo
Sep 28, 2015 01:37 PM
Iceberg
Sep 28, 2015 01:31 PM
SlowSaturn
Sep 28, 2015 11:03 AM
