15" On SS/SC
Old May 14, 2006 | 06:21 PM
BooSSted's Avatar
15" On SS/SC
Do 15" Rims fit on the SS/SC. I need to know before I buy drag radials
Old May 14, 2006 | 07:19 PM
05YELLOWSS's Avatar
not without some kinda crazy spacer setup, just buy 16's and 16" dr's
Old May 14, 2006 | 11:54 PM
BooSSted's Avatar
What does a spacer have to do with it? I need to know if the rims will fit over the calipers!
Old May 14, 2006 | 11:56 PM
distillion's Avatar
nope.
Old May 14, 2006 | 11:57 PM
R33P3R007's Avatar
360 L337 User
yes with a SPACER SETUP.....what are u a noob. thats what a spacer has to do with it.
just go 16 till bogart releases the 15 with built in SPACER
Old May 15, 2006 | 12:08 AM
SS4LIfe's Avatar
what type of spacer are you talking about.
Old May 19, 2006 | 09:40 AM
BooSSted's Avatar
Are you fucked? What does a spacer have to do with the inside diameter of the wheel and the size of the rotor and caliper? A spacer is going to fix offset, not size. Only way a spacer is going to wprk is it you drive around like a Gino with 14" Daytons on a caravan sticking 9 inches out the side of the van.
Old May 19, 2006 | 10:59 AM
Gorilla unit 33's Avatar
not true. ^^^ the caliper is angled on the edge, and adding the spacer moves the wheel out so it will fit. thats why the spacer is needed to fit the 15 on the ss/sc. and wheels are not all straight on the inside, they are curved too, so it does make a difference.
oh yeah.. ARE YOU FUCKED. idiot.
i'm a noob here and have already read all this in other posts. check the search button.
PS. Are you fucked. <-- how stupid is that.
Old May 19, 2006 | 11:29 AM
BooSSted's Avatar
That's exactly what I just said "G-Unit". The spacer will have to be big enough to push the wheel out to clear the caliper. I don't want that. If a 15" won't fit then I will go to 16". I am not going to rig up a spacer setup and change my lug bolts everytime I go to the track.
You wanna start calling people an idiot? Look at your ******* screen name, Then look at what you put for your location.........No matter how hard you try, Your never going to be 50 Cent! ***
Old May 19, 2006 | 12:42 PM
BlackBalt's Avatar
Relax guys , save the anger for the imports.
Old May 19, 2006 | 05:45 PM
IonNinja's Avatar
you won't need to "rig up" a spacer and change anything out...its not going to take a 10mm spacer to fit 15" wheels on the SS/SC (if they fit).
at most you are going to need a 5mm spacer which will still allow you to run 15" wheels on the SS/SC, but will stop the spokes from coming in contact with the caliper.
But anyway, in all honesty I doubt it'll fit.
Old May 19, 2006 | 05:49 PM
OniMirage's Avatar
OMG
Old May 19, 2006 | 10:55 PM
CARLYLE's Avatar
some one lock this post its getting so fucktarded
Old May 22, 2006 | 12:35 AM
LewiSS's Avatar
Someone already physically tried this. See the post:
https://www.cobaltss.net/forums/wheels-tires-96/wheel-fitment-f-q-stock-wheel-f-q-how-get-wheels-your-cobalt-read-me-8149/
Here's what he said:
b) 15" 5x110.. fit perfectly as far as bolt pattern goes of course, but the calipers were in the way and it wouldn't go all the way back.. no dice.
c) 16" 5x110.. this was the last one they tried.. and success! they were only 59.99 too, sweet dealio.. I will have to purchase new nuts however for the wheels too, since in order to get the steels tight, I'd have to pop right through the ones for the stock wheels. (the stock wheels are thicker on the bolts).
When we went to look for tires, I think someone already mentioned it here, our complete radius stock tires is about 25.6", if you get 205/60/16 tires.. that would put you in the facinity of 25.7" which should be just fine.
Old May 22, 2006 | 05:50 PM
BooSSted's Avatar
https://www.cobaltss.net/forums/showthread.php?t=8149
Thank You Very Much!!
Old May 22, 2006 | 05:55 PM
hatrickstu's Avatar
wow you guys got way to upset over stupid little comments
Old May 22, 2006 | 08:08 PM
IonNinja's Avatar
205/60/16 might be a little beefy looking though...I'd try to find a 215/55/16 or 205/55/16 tire
Old May 22, 2006 | 09:17 PM
beerbaron105's Avatar
here are my 16's on my car
there are bare millimetres between the caliper and the rim, so its a definite no unless u have spacers and no idea if that would even work or how big you would have to go
Old May 23, 2006 | 08:49 PM
tiny's Avatar
haha, that guy's name is Gorilla Unit, hahhahaa
its Guerilla Unit, buddy
Old May 23, 2006 | 08:52 PM
YoAdrian's Avatar
No kidding.
Old May 23, 2006 | 09:27 PM
mi6_'s Avatar
No! 15" wheels will not clear the front rotors! I have 16" steelies for the winter, and there is like 3/8" clearance between the rim and the brake rotor.
turboecotec02
Nov 26, 2015 10:43 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
satisfied
Oct 19, 2015 12:35 AM
Bluelightning
Sep 8, 2015 05:18 PM
