16" Catera Wheels on SS-SC - Need HELP
Old Sep 11, 2006 | 11:16 PM
automobiliben's Avatar
Ok, so I finally received my Catera wheels that I bought off of eBay today. They are 16X7, 42 mm offset, and weigh 20 lbs. a piece. My question is: look at the clearance between the wheel and caliper. There is probably 2 mm of clearance. Does anyone know if this will be a problem? The wheels are pretty beefy, so I doubt they will flex much. The thing I was worried about would be the caliper thermally expanding. I was thinking about using these for road racing, since 16" tires are cheaper. But I think I will run into problems. Personally, I think these would be fine for drag wheels. Please help me answer my questions. Thanks.
Old Sep 11, 2006 | 11:19 PM
patathSS's Avatar
Eh, my 15s are tighter. Do calipers really expand that much?
Old Sep 11, 2006 | 11:24 PM
Shortbus's Avatar
My 16inch wheels are working out well, i have drag-radials on them also, there is no fender gap, they do stick out a good bit too.
Old Sep 11, 2006 | 11:27 PM
Everything expands, and I am sure once you would heat them up to 500* or so that they would easily expand that distance. How did you get 15" to fit? Also, I doubt your 15s are tighter (wheel to caliper) unless there would be interference.
Old Sep 11, 2006 | 11:28 PM
patathSS's Avatar
If you are really worried about clearance grind your calipers.
Old Sep 11, 2006 | 11:40 PM
Listerman's Avatar
16s at 20lbs each? seems kind of heavy to me.... whats the purpose of these wheels?
Old Sep 11, 2006 | 11:44 PM
Erod's Avatar
Moderator Alumni
Bolt them on.
Old Sep 11, 2006 | 11:45 PM
They are heavy because they are OEM. Not nice aftermarket aluminum. I picked them up off of eBay for $175 shipped. I bought them for winter wheels, but am trying to weigh the options.
Old Sep 11, 2006 | 11:47 PM
patathSS's Avatar
yeah i looked at them. i would agree with Erod and bolt them on.
Originally Posted by Erod
Bolt them on.
Umm, is that a joke?
Did you not look at the pictures or read......that is my car with the wheels bolted on......
Old Sep 11, 2006 | 11:54 PM
mi6_'s Avatar
I run 16" steelies in the winter. They have about 3/8ths of an inch clearance on the front calipers, and they were OK. I just made sure that no snow or ice piled up in them.
I can't put my finger in one of the holes between the caliper and the wheel because there is not enough room. I was kind of worried once I saw it, but I didn't have any problems, and the wheels were burried in snow and ice more than once this past winter.
Old Sep 11, 2006 | 11:58 PM
patathSS's Avatar
Mine are tight. I think less gap than yours.
Old Sep 11, 2006 | 11:59 PM
So a 15" SAAB wheels will fit? Damn, I thought people said they wouldn't....
Old Sep 12, 2006 | 12:07 AM
patathSS's Avatar
It takes some ingenuity and creativity but it fits.........
with machining.
Old Sep 12, 2006 | 12:42 AM
with machining.
What had to be machined? The spokes I take it? What tires are you running on there? Better be some DRs...
Old Sep 12, 2006 | 12:44 AM
patathSS's Avatar
No I machined the calipers. I run a 235-60r15 Drag tire on them. M&H Tires My next set is a M&H slick.
My garage has some pictures of the calipers on the car without wheel. You can kinda see how much I took off.
I just checked out your gallery and answered my own question. But what about the macining part? 15 DRs would be better than 16s, but I might as well use what I got.
Old Sep 12, 2006 | 12:45 AM
Ughh, that is out of the question for me, I want to run road cours too and wouldn't want to machine the calipers.
Old Sep 12, 2006 | 12:48 AM
patathSS's Avatar
Stick with 16s then. its just hard to find slicks that will fit in our wheelwell that our 16". I know of about 4 tires i can run just from M&H.
Old Sep 12, 2006 | 12:50 AM
I plan on going with the Hoosie QTPs, a couple people on here are running them with 16s.
Old Sep 12, 2006 | 12:53 AM
patathSS's Avatar
yup they are a good drag tire. there just aren't a lot of slicks for us besides the QTPs in 16"; none to my knowledge
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
DANRICKARD
Oct 1, 2015 12:08 AM
