18x8
Old Nov 20, 2011 | 09:22 PM
AyrtonSenna's Avatar
18x8
I'm lowered on Pedders coils, I have 15mm spacers in front and 5mm spacers in the rear. For the summer I'm planning to get 18x8 wheels with 245/35 tires. I'm wondering if they will fit without rubbing or any other problem
Old Nov 20, 2011 | 09:23 PM
Dart_SI's Avatar
They'll fit. The rear sits a little high on pedders so Youl be ok.
Old Nov 20, 2011 | 10:12 PM
Actually I set my coils kind of low in the rear too, but thanks for the info
Old Nov 20, 2011 | 10:15 PM
Dart_SI's Avatar
Oh. Thought u were on springs. Lol. You might have to roll your rear fenders.
Old Nov 20, 2011 | 10:18 PM
Or i will just remove the spacers
Old Nov 20, 2011 | 10:24 PM
Dart_SI's Avatar
You could but it might still rub on 245's. My wheels are +35 and if I hit a big bump they rub a little. Its not a lot tho. U should be fine.
Old Nov 22, 2011 | 02:00 AM
I was PMd saying that the 18x8 with the 245/35 should be ok. I'm oriented toward the Yokohama Advan Sport. Anyone can give me any suggestion for an eventual better tire?
Thank you
Christian
Old Nov 22, 2011 | 05:36 PM
doc@tirerack's Avatar
Supporting Vendor
Thank you
Christian
I'd guess you'll have to ditch the spacers to get the 245 to fit if lowered. Unless you track the car I'd have you look at the Conti Extreme Contact DW or Bridgestone RE760. They're not quite as sticky as the Advans but a little more durable and alot less expensive....
Old Nov 22, 2011 | 09:53 PM
Thanks for the advice. But if I'm looking to go with wider tires is because I want more traction, I don't really care if the Advans are less durable and more expensive
Old Nov 22, 2011 | 10:13 PM
09sscalicobalt's Avatar
235/40/18 is what i have on a 18x8 and its the perfect fitment... dunno if 245/40/18 will fit with spacers especially if your low...
Old Nov 22, 2011 | 10:24 PM
But I'm going with 245/35, not 245/40
Old Nov 25, 2011 | 09:44 PM
eh whatever youll be fine lol
Old Nov 25, 2011 | 09:55 PM
ericgt79's Avatar
i had 18s with a lock ring out of my stance coils you will be perfectly ok, man up tho and go lower. the wheels will roll the fenders for you
Old Nov 26, 2011 | 08:38 AM
Bumpin Balt's Avatar
If you are dropping to a 35 profile, go with 255/35's. It has been done and they fit just fine without rubbing. I would look for an 8.5" or 9" wide wheel to go with them though.
Old Nov 26, 2011 | 12:15 PM
Dart_SI's Avatar
my front wheels are that size, but im still on 18X8's. doesnt look to bulge or anything but i definently wont be going up a size unless i get wider wheels.
the wider tires work wonderfully tho.
Old Nov 26, 2011 | 06:12 PM
255/35 will fit on a 18x8? Wow that's good news! Thanks guys!!!
Old Nov 26, 2011 | 06:29 PM
whyyoumadson?'s Avatar
you dont need 245s up front... its almost too much tire on a 18x8... your better off with a 235 and get better traction mods such as bags in the back or something.... you can go wider and wider with the tires alllllll u want but without proper suspension or a very progressive torque curve to get traction whats the point?
Old Nov 26, 2011 | 06:43 PM
Well so far I have Pedders Xa coils. And OTTP stage 2 tranny and TTR upper engine mount. What else can I get for better traction other than wider tires?
Old Nov 27, 2011 | 01:19 AM
Looks like that the Yokohama I'm looking for, they are more or less the same price either 245/35 or 255/35
Old Nov 27, 2011 | 01:47 AM
Whining-devil's Avatar
id stick with 235's and go max 245's on a 8" rim.
Old Nov 27, 2011 | 01:55 AM
idk why your using the ttr upper with ottp lowers.... not a good combination. the ottp lowers are limited to their adjustment by the ttr upper.
drag bags, travel limiters, you could fabricate a reverse torque arm if you wanna do sometihng really trick. slicks lol.
Last edited by whyyoumadson?; Nov 27, 2011 at 01:55 AM. Reason: Automerged Doublepost
Old Nov 27, 2011 | 03:50 AM
I have no idea of how to fabricate that stuff lololololol. But wider tires are on my list and I will def get them. I want the widest foot print possible.
I got the TTR mount because it came painted to match other things that I've got powder coated in my engine. I have to be honest, it seems fine to me.
dieGone
Sep 23, 2015 10:20 AM
Black05
Wheels and Tires
Oct 28, 2008 04:43 PM
Listerman
May 10, 2008 09:16 AM
gtx28
Wheels and Tires
12
Mar 1, 2008 09:55 AM
SilverSS/SC
Wheels and Tires
43
Feb 7, 2008 08:03 PM
