18x8
18x8
I'm lowered on Pedders coils, I have 15mm spacers in front and 5mm spacers in the rear. For the summer I'm planning to get 18x8 wheels with 245/35 tires. I'm wondering if they will fit without rubbing or any other problem
I was PMd saying that the 18x8 with the 245/35 should be ok. I'm oriented toward the Yokohama Advan Sport. Anyone can give me any suggestion for an eventual better tire?
Thank you
Christian
Thank you
Christian
I'd guess you'll have to ditch the spacers to get the 245 to fit if lowered. Unless you track the car I'd have you look at the Conti Extreme Contact DW or Bridgestone RE760. They're not quite as sticky as the Advans but a little more durable and alot less expensive....
the wider tires work wonderfully tho.
you dont need 245s up front... its almost too much tire on a 18x8... your better off with a 235 and get better traction mods such as bags in the back or something.... you can go wider and wider with the tires alllllll u want but without proper suspension or a very progressive torque curve to get traction whats the point?
idk why your using the ttr upper with ottp lowers.... not a good combination. the ottp lowers are limited to their adjustment by the ttr upper.
drag bags, travel limiters, you could fabricate a reverse torque arm if you wanna do sometihng really trick. slicks lol.
Last edited by whyyoumadson?; Nov 27, 2011 at 01:55 AM. Reason: Automerged Doublepost
I got the TTR mount because it came painted to match other things that I've got powder coated in my engine. I have to be honest, it seems fine to me.
SilverSS/SC
Wheels and Tires
43
Feb 7, 2008 08:03 PM
