225\40\18 Khomo Esta SPT
Old Aug 13, 2007 | 02:03 PM
Vetteman-sssc's Avatar
I just ordered a set of 4 of these tires for my Cobalt SSSC in 225\40\18.
How many people have these tire in this size and how do you like them over all??
I know the Pzero are garbage so I went with these instead and got them from Tiredirect.com " thanks forum member for the recommendation, once I pull up the name you get rep points from me "
I see some people are running 225\45\18 wich I here will run the speedo way off so I got them in 40 series wich is closer to the stock tire "215\45\18 " speedo speeds but maybe 1mph off.
Just like to get forum members input on the Khomo's.
Thank You
Old Aug 13, 2007 | 02:12 PM
hoffa's Avatar
i bought a set of 215/35/18 kumho ecsta asx's.
love em
Old Aug 13, 2007 | 02:21 PM
06_SS_S/C's Avatar
I have had two sets of Kuhmos in the past on other vehicles, can't beat em for the price.
Old Aug 13, 2007 | 02:24 PM
Witt's Avatar
I have them in stock size (215/45/18) and love them. For the price you can't beat them.
Old Aug 13, 2007 | 02:30 PM
rick1217's Avatar
Kuhmo makes some awsome tires for the price..... I am currently running some Federals in the 225/40s....cause i got them for a decent price but before I had some Kuhmos Exsta Supras i think and there were great tires, also had them on my 87 Supra before i had my Cobalt and they were great too..... These Federals SS 595 have a pretty good bang for buck too.....
But I agree totally, those P-Zeros are grabage, and way overprice for a shitty tire....
I drive abit fast sometimes so tires dont usally last long but
P-Zeros- rotating them often but all 4 only lasted about 6000km WAY overpriced
Kuhmos- Rotated abit, lasted about 12000km -Cheap
Yokahoma winter AVS, lasted about 16000km, wheel spin on ice/snow doesnt wear tires as much as pavement....-little expensive.....
Federals- had them for a little over 11000km and theres still about 50-40% thread on them.....-Cheap
Old Aug 13, 2007 | 03:10 PM
Cool Im glad to hear you all have had good luck with them.
I cant wait to get my bald Pzeros off my car they only have 30 000 on them and ive rotated them every oil change and they are gone.
Ps no burn outs either ... LOL!!!
Now I have another problem with my Balt I have to get fixed and its been to dealer 4 times and they dont hear it and thats a click\popping noise when changing gears and going in reverse.
Im reading it maybe CVU joints in axles
I just had my Gunmetals rims repainted do to clipping and now I have this issue with clicking.
Does the problems ever end with these cars???
Damn you CHEVY !!!!!
Old Aug 13, 2007 | 05:49 PM
rick1217's Avatar
Depending on what it sounds like, it might be normal....I know when shifting to reverse on most cars, it makes a little click/pop noise.... sometimes on a hard 1-2 shift I get a click/pop.... how many miles do you have on your car??I know at first my trans was really stiff and didnt like shifting fast, but now it is broken in....
Old Aug 17, 2007 | 08:05 AM
SSinPA's Avatar
just to point out the width of a tire (ex. 215 to a 225) does not change the speedo. Going to a smaller aspect (ex. 45 to 40) will change the speedo.
Old Aug 17, 2007 | 08:08 AM
astrocrep's Avatar
225/45/18 will run you a little slower then the speedo says...
225/40/18 will run you a little faster then the speed says...
I went with the 225/45/18 (Protenza 960as) and love them.
-Rich
Old Aug 17, 2007 | 08:11 AM
1stbluSS's Avatar
I have them
225/40/18
Plus side - Better tread wear, wider patch for better grip, cost, design
Minus side - They take longer to heat up, bad grip in the cold
Old Aug 17, 2007 | 08:15 AM
SSinPA's Avatar
how will 225 run you slower the circumference is the same because the aspect ratio is still 45 just like stock width has nothing to do with it
Old Aug 17, 2007 | 08:16 AM
1stbluSS's Avatar
my 1/4 times were better once I heated these up. Better contact
Old Aug 17, 2007 | 08:20 AM
Kahless's Avatar
because the aspect is the % of the width of the sidewall compared to the width of the tread. 45% of 225 its wider than 45% of 215 which means the tire is taller and screws with the speedo.
Old Aug 17, 2007 | 08:25 AM
SSinPA's Avatar
oh
so going 225/40 is better?
Old Aug 17, 2007 | 08:41 AM
Kahless's Avatar
would make it closer to the original tire height. here is what i have and what im switching to
have
235/60/14
9.25 tread width / 5.55" sidewall
828.6 revs per mile
25.1" high
getting
275/40/17
10.82" tread width / 4.33" sidewall
810 RPM
25.66 high
255/40/17's would keep my speedo on because they are 830RPM and 25.05" high
Old Aug 17, 2007 | 08:49 AM
Rangerondubz's Avatar
-Rich
You got that comparison backwards, the bigger the tire, the faster you will be going and your spedo should be the same since they come w/ 45 series tires. The 40 series you would be going slower then your speedo says
Old Aug 17, 2007 | 08:52 AM
BriantheLion26's Avatar
Yeah you are right. Mine stock with the 215/45/18s read fast. I would read going like 70 and I clocked it radar and with another car with factory tires, both said we were going like 67-68. I figured they already read fast, why go to a 225/40, it would just make it worse. I got 225/45/18s and it should be pretty much right on, maybe a hair slow, big deal. A 225/40 will just make you say you are going faster but you really arnt.
Old Aug 17, 2007 | 08:53 AM
So how is the traction on these tires?
Old Aug 17, 2007 | 08:54 AM
Kahless's Avatar
what also needs to be said for any of this... take it to the dealer and they can reflash your ecu to recalibrate your speedo to make it right.
Old Aug 17, 2007 | 09:02 AM
Everyone says they seem to be good for the price. I actually got Falken FK 452s at www.discounttiredirect.com Cheapest place I could find them. The SPT is the cheapest then the falken I got. I love the falkens, pulled a 2.226 60' at 25psi the first time I ever went to the track. I would say they grip pretty good.
Old Aug 20, 2007 | 08:25 PM
Well all the tires are awesome"Khomos".
What a big differents over the Rosso's.
Thanks All for your help.
bigdeertz
Nov 17, 2016 09:41 AM
nathan112i
Sep 30, 2015 07:12 PM
AdamRedSS
Wheels and Tires
Mar 24, 2007 03:07 AM
jfaphoenix32
Feb 23, 2007 08:04 AM
