235/40/18 or 245/40/18??
Old Feb 18, 2010 | 01:12 PM
cresintern's Avatar
so its been discussed but with sstc's what is best ? 235/45/18, 235/40/18, 245/45/28 or 245/40/18 ??? which will rub if any?? and which, if any will alter speedometer??
Rissa's Avatar
Well are you lowered?
Old Feb 18, 2010 | 01:14 PM
JPizzle's Avatar
I say go big or go home...
Old Feb 18, 2010 | 03:57 PM
firerat's Avatar
I saw definitely go with the 245/40/28.
Old Feb 18, 2010 | 05:30 PM
cobalt1's Avatar
Old Feb 18, 2010 | 05:37 PM
badbaltguy's Avatar
235/40/18 wider than stock, im lowered, and no rubbing...
Old Feb 18, 2010 | 06:01 PM
Rissa's Avatar
Depends on what you are lowered on...I should have specified.
Old Feb 18, 2010 | 06:07 PM
ecotecturbo's Avatar
A Girl giving advice.
Old Feb 18, 2010 | 06:11 PM
Rissa's Avatar
Lol everyone I know whose gone bigger tires has rubbed, 235's and 245's.
Nighthawk243's Avatar
Please... don't donk the balt.
Old Feb 18, 2010 | 06:16 PM
CudaJoe's Avatar
I just used a wheel calculator on that specified size.... damn thats huge lol.
http://www.wheelsmaster.com/rt_specs.jsp
Wheels:-------------Wheel 1------------Wheel 2
Wheel size---------18x8.5 ET 42----------28x8.5 ET 42
BackSpace--------162 mm (6.4'')---------162 mm (6.4'')
Tires:--------------------Tire 1------------------Tire 2
Tire size---------------225/40-18------------245/40-28
Section width-------225 mm (8.9'')---------245 mm (9.6'')
Sidewall-------------90 mm (3.5'') ---------98 mm (3.9'')
Tire diameter-------637 mm (25.1'')---------907 mm (35.7'')
270 mm (42.4%) taller.
*Seems TOO tall.
Rim sizes-----------18x6.5 to 18x8.5--------28x7 to 28x9
Circumference-----2000 mm (78.7'')------2848 mm (112.1'')
Revs per mile ------------804.6 ------------------565.1
Speedometer Assuming that this is OEM tire and speedometer readings are correct When speedometer reads 60mph (96.6km/h) actual speed will be 85.4mph (137.5km/h): 42.3% faster.
Clearance: Package 1
Assuming that this is OEM wheel/tire and there is no any problems with clearance on both sides Package is 10 mm (0.4'') closer to suspension/brakes components. Acceptable for most cars.
Fenders
Package will stick out 10 mm (0.4'') farther. Acceptable for most cars.
Wheelwells
Will fill out the wheelwell by extra 135 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rims.
Old Feb 18, 2010 | 06:28 PM
firerat's Avatar
Dude, it was a joke. I was just being a smartass because the other dude made a typo.
Old Feb 19, 2010 | 01:03 PM
cresintern's Avatar
no, stock set up.......
Old Feb 19, 2010 | 01:08 PM
Rissa's Avatar
You should be fine then if you plan on staying that way.
Old Feb 19, 2010 | 01:10 PM
cresintern's Avatar
so which size should I go with
Old Feb 19, 2010 | 01:16 PM
Rissa's Avatar
Whatever you think looks better, 245's look too meaty to me.
Old Feb 22, 2010 | 10:21 PM
DARIN616's Avatar
I was wanting to go with 235's but I'm lowered on H&R's and I rub with the stock tires, so I'm thinking I have no choice but to stay with 225's
Old Feb 23, 2010 | 02:01 AM
CrystalRedSS's Avatar
Where exactly do you rub with H&R's cuz I plan on getting them when summer finally decides to get here. Are you rubbing really bad?
Old Feb 23, 2010 | 02:13 AM
Rissa's Avatar
I don't rub with my H&R's and I'm on 225's.
Old Feb 23, 2010 | 03:32 AM
87gn06gto07irl's Avatar
245/40/18 works for me but im not lowered. And i have a redline
Old Feb 23, 2010 | 09:02 AM
JERMzSS's Avatar
235s
Old Feb 23, 2010 | 10:36 PM
DARIN616's Avatar
It only rubs when the wheel is cranked completely, like when your doing a u-turn. Its not a rub that will inflict any damage in any way, I think the tire is just skimming the plastic inside the wheel well. Get the H&R's though for sure, they are worth it; the rubbing is so easy to avoid and they are more comfortable than the sportlines IMO.
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
themacguy
Aug 26, 2015 07:18 PM
StevesBlack06
Wheels and Tires
Jul 19, 2009 10:09 PM
firestorm
Wheels and Tires
20
Sep 15, 2007 12:38 PM
