245/40 18's on a 40mm
Old Aug 28, 2007 | 01:07 PM
Jackalope's Avatar
Will they fit? Anyone know?
14 views and no comments? Does noone know?
Old Aug 28, 2007 | 01:10 PM
vtecduster's Avatar
on a 40mm? What does that mean? I assume you're talking about tires on a wheel, but the 40mm means nothing to me. What is your wheel width in inches?
Old Aug 28, 2007 | 01:12 PM
Jackalope's Avatar
Sorry the wheel is an 18x8 with the offset being the 40mm. Didn't mean to confuse anyone my bad.
Old Aug 28, 2007 | 01:15 PM
vtecduster's Avatar
they should fit, you may want to go even a bit wider though. I'm going 235 on a 7.5 in a couple weeks here. Check prices on a 240/40 vs. a 245/40. One will be cheaper depending on the popularity of the tire size...sometimes the bigger one.
..and move the comma in your sig to after the word "be"
Last edited by vtecduster; Aug 28, 2007 at 01:15 PM. Reason: Automerged Doublepost
Jackalope's Avatar
Cool thanks! Yeah I fould some wheels I want and now I'm looking at tires but I want a nice beefie looking set of rubber under the car hence the 245/40's
Old Aug 28, 2007 | 01:47 PM
SpectorV's Avatar
245mm wide tire on an 8 inch rim will work fine. Just make sure the overall sidewall height is correct (is a percentage of the width, not just a number in height)
Old Aug 28, 2007 | 02:01 PM
Jackalope's Avatar
I know the 245 will work on the rim I'm more worried about rubbing issues with the fender well. But thanks for the help!
Old Aug 28, 2007 | 02:58 PM
DrPuttsSS/SC's Avatar
Jack I think you'll be good.
Isn't stock offset something like 42mm? I've heard people say that 38-45 is ok.
As far as the width, I know that the Grand Am racing Cobalts run 245 Hoosiers, but on 17" wheels, and I don't know the offset. I got to talk with 2 of the teams two yars ago and they didn't have any clearance problems.
With stock offset, half inch wider wheel and 30mm wider tire it seems to me you may have as much as 3/4" more beef on each side of wheel.
Unfortunately most tires aren't exactly the size they're marked and sizes vary according to manufacturer. So it seems like you'll almost have to buy and try them unless someone here has a setup close to what you want.
And obviously you may already know all this, just tryin to help.
Old Aug 28, 2007 | 03:30 PM
Jackalope's Avatar
Thanks man great info! Its at least good to know that someone has tried them before.
Old Aug 28, 2007 | 04:08 PM
You're welcome man! I bet that combo will look BAD ASS!!!
Old Aug 28, 2007 | 04:09 PM
Jackalope's Avatar
Just wait you'll see.
Old Aug 28, 2007 | 04:15 PM
Blue_ghost's Avatar
235/40/18 is what you need to keep near stock diameter for the 18" SS wheels. Going to this size from the 215's is within 0.1 of the OEM tire. I have 235's on all 4 stock wheels and have NO rubbing issues. There are plenty of websites that will do the conversions for you.
Old Aug 28, 2007 | 04:19 PM
Jackalope's Avatar
From what I remember I thought the 235 was a tad smaller and the 245 a hair larger then stock diameter. I don't want to step down in sidewall cause the roads around here suck ass! I NEED that sidewall to protect my rims AND smooth out the ride as much as possible. The 235's are smaller aren't they?
Old Aug 28, 2007 | 04:25 PM
06_SS_S/C's Avatar
Yeah, 245s would be a tad taller and 235s would be a tad smaller with the 40 profile
Old Aug 28, 2007 | 04:46 PM
I had checked this before (with my cheap TI calculator), and doing the math:
215/45-18"= 25.618" diameter
235/40-18 = 25.402"
245/40-18 = 25.717"
The 245/40 is a tiny bit closer to stock diameter, .099 larger, while 235/40 is .216 smaller. Not a big difference either way, roughly 1/2 of 1%, nothing anyone would ever notice.
But these numbers are theoretical. The problem with just doing the math, like I said earlier, is that nobody makes a perfect tire that is exactly the size it is supposed to be in every dimension, and tires marked the same size often vary according to manufacturer.
That's why I wrote before that in the end he'll just have to buy and try em!
Just my 2 cents, your reality may differ.
Wow, that's a great chart! Where'd ya find it? Would save me from crunching numbers.
Last edited by DrPuttsSS/SC; Aug 28, 2007 at 04:46 PM. Reason: Automerged Doublepost
Old Aug 28, 2007 | 04:47 PM
06_SS_S/C's Avatar
1010tires.com
Its a great website for compare tire/wheel sizes and stuff.
Old Aug 28, 2007 | 04:53 PM
1010tires.com
It sure is! It's great that they show what your speedo will do too. Thanks!
Old Aug 28, 2007 | 05:04 PM
sick_ss/sc's Avatar
i got 245/40/18 on my stock rims and they fit good
Old Aug 28, 2007 | 05:12 PM
That's the kind of info we need, thanks! Not just theoretical maybes.
Old Aug 28, 2007 | 05:17 PM
Blue_ghost's Avatar
Sorry...I had a typo! 245 is what I have. My Bad. Thank you for posting the chart.
Old Aug 28, 2007 | 05:26 PM
Jackalope's Avatar
AWESOME so the 245's WILL fit with no issues on an 8 inch wide wheel! Perfect guys + rep for everyone for thier help!
Well everyone exceot 06 SS, says I have to spread it around some more. Sorry man.
Old Aug 28, 2007 | 07:11 PM
Wow, thanks Jack, my rep really jumped, I appreciate it.
Off topic but is it 100 rep points per box? If so I'm gettin pretty close.
What's with these guys here with like thousands of posts and one green box?
Finally got my account straightened out and can now give rep, I think, haven't tried it yet, but + back at ya.
Old Aug 28, 2007 | 07:32 PM
Jackalope's Avatar
Its 100 per box till you hit 5 or 6 boxes then you skip for some reason to 200 till the next box then it drops back to 100 per box then when you hit 800+ points it looks like it might skip again. Noone knows why it does what it does not even Jonel!
EXAMPLE, I'm at 871 points yet I have only 7 boxes. WHO KNOWS!
Old Aug 28, 2007 | 07:46 PM
Thanks again man! You have the most green I've noticed here, that's for sure.
Old Aug 28, 2007 | 07:53 PM
Jackalope's Avatar
Yes I am the REP KING! LOL!
