4x100 to 5x114.3 Re-drill - Info & Questions
Old Mar 16, 2013 | 08:10 PM
Steviodaddio's Avatar
I whipped up a quick sketch on AutoCAD of a spacer (it's actually the size of a rotor, ignore the major width) with 4x100 holes as well as 5x114.3. One hole over-laps partially and the rest are fine. Based on the picture below, would that overlap effect the stud being pressed into a hub and cause issues with the bolt wobbling or not mounting tightly? Seems like a pretty basic thing to do unless I'm overlooking something major or there is a major flaw in drilling it this way.
Uploaded with ImageShack.us
Also, why have I heard that you need a stud presser to re-press studs into a hub? I see guys doing it with a hammer and the wheel lug. vvv
Old Mar 18, 2013 | 07:26 AM
justin709's Avatar
I repressed mine with a bench vice and socket.
Old Mar 18, 2013 | 12:38 PM
Any clue about the overlapping holes if that'd be an issues? Also on a stock 4x100 09' XFE hub would a 5x114.3 fit or is the diameter of the hub not large enough?
Old Mar 18, 2013 | 01:03 PM
68nova200's Avatar
if you tweaked the holes a little they can be drilled without overlap. i just tried on pro/e.
Old Mar 18, 2013 | 01:11 PM
EXsoccer1921's Avatar
don't press a stud in to that. just get 5x110 hubs and redrill those. or get adapters.
Old Mar 19, 2013 | 10:17 AM
I can't run adapters with a 9.75" wheel and a +25 offset unless I want to be running some 0 or negative offsets. lol
Won't the spline count be off once I change to the 5x110 hub?
Old Mar 19, 2013 | 10:56 AM
don't quote me on this, i never did look in to it to confirm what he said. but i was talking with a guy who said he had the powell bbk kit on his 4 lug. swapped over to 5 bolt hubs from an lsj. he was saying that the outboard spline count and diameter for the ls axles is the same as the lsj axles. so you can swap hubs, just not axles. for the rears you'd have to go to a disk setup (if you have drums currently). if you already have disk then it will be a simple hub swap there as well.
you can't drill 4bolt and 5bolt patterns on a hub but you can do it on rotors.
Old Mar 19, 2013 | 11:28 AM
How come a 5x110 and 5x114.3 can be drilled on the same hub but the 4x100 and 5x114.3 can't? Is that due to hub diameter or was that answered when you said don't press a stud into an overlapping hole?
I really didn't want to have to do a whole rear disc conversion since it seems from what I've read I'd have to swap the whole rear out for an aftermarket kit or an SS rear. :/
Old Mar 19, 2013 | 11:39 AM
you can do 5 on 5 because the holes won't be touching. they'll have even space in between them. 4 on 5 will have one touching. which is not safe to press a stud in to.
Old Mar 19, 2013 | 11:58 AM
2009CobaltLT's Avatar
Correct on the LSJ hubs, splines are the same as LS
And don't overlap the holes, that's just asking for trouble
Old Mar 19, 2013 | 05:12 PM
I like to live life on the edge a little though. ;P
If I pick up a set of LSJ hubs does that mean I have to do a break conversion in the back or will the hub itself mount inside the drum where the drum can be redrilled to fit the pattern change?
Old Mar 19, 2013 | 09:02 PM
now that i'm not sure of.
Old Mar 19, 2013 | 09:18 PM
2000Firehawk's Avatar
You can overlap the holes, welding that stud will be needed.
I had 4 x 100 put onto my 5 x 110 hubs by member ItailianJoe1.
Been on my DD x 6 months now, no problems, & 12.5s at the track...
http://www.chevyhhr.net/gallery/file.../0/photo-9.JPG
Old Mar 19, 2013 | 09:29 PM
tpete763's Avatar
I converted my LS to a 5x114.3 pattern. You need to get LSJ hubs for all 4 wheels to re-drill them, I had Jeff (Screen Name Mongorat) re-drill mine for me. YOU DO NOT HAVE TO SWAP TO REAR DISCS FROM AN LSJ TO CONVERT TO 5 LUGS, I DIDN'T.. Chevy made cobalts with a 5 lug rear drum. just buy those drum brakes and drill the 5x114 pattern on to them the will literally bolt right up to your drums. with the conversion.
Link to Drums:
http://www.ebay.com/itm/Cobalt-HHR-Pontiac-G5-2-80122-Brake-Drum-5-Lug-Drum-/220734754678?pt=Motors_Car_Truck_Parts_Accessories&hash=item3364d10f76&vxp=mtr
To do this conversion you will also need an LSJ brake setup for the front. your calipers will be too small for them to bolt up to the new, larger discs.
Old Mar 20, 2013 | 11:35 AM
he can keep the ls rotors and calipers. the rotors you can drill the 4x100 and 5x114.3 in to. overlapping is fine there.
Old Mar 20, 2013 | 01:46 PM
Link to Drums:
Cobalt HHR Pontiac G5 2 80122 Brake Drum 5 Lug Drum | eBay
I found LNF / LSJ hubs that Mongo is selling but he said LNF and LSJ which kind of confused me. I asked him the same the same question but aren't the spline counts for the LSJ and LNF different? Not sure if that was an error on his part or if there's a hub that's universal for the 2.
So..
  • LSJ Hubs Re-Drilled to 5x114.3
  • 5 Lug Drum Cover Re-Drilled
  • My LS Rotors Re-Drilled
How long do hub swaps generally take? Seems pretty straight forward but I've never had to remove the hub itself. Is there anything I should know to do or not to do? lol
Old Mar 20, 2013 | 01:58 PM
correct lsj (05-07 supercharged) and lnf(08-10 turbo) are different spline count and diameter. you want lsj hubs in the front, redrilled to 5x114.3. they will go right on to your current setup. you redrill your current rotors as well. even though they're 4x100, rotors can have holes overlapped because there won't be anything pressed in to them like with the hubs. so you can just redrill them and keep your same rotors and calipers.
for the rear drums i'm unsure on what you actually need to do, you should just be able to drill your current drums, unless the drum itself is what the studs press in to but that doesn't seem right. there should still be a hub. inwhich case you just run the lsj rear hubs, redrilled. and redrill your drums.
Old Mar 20, 2013 | 02:13 PM
This
Old Mar 20, 2013 | 02:51 PM
Alright, cool. Hopefully he gets back to me and tells me they're LSJ hubs. I thought Mongo's car was a turbo swapped LSJ so we'll see.
Here's what I found out about the rear drum. There is still a hub, to answer that, so the studs wouldn't be pressed into the drum itself.
There was another thread I found about a 2.2l rear disc break conversion.
https://www.cobaltss.net/forums/susp...ersion-137853/
I'm just curious now if a LSJ hub would fit correctly inside and butt up to the original 4x100 drum since the hub diameter is larger. I figure I'll need to buy the 5x110 5 lug drum cover unless the 4x100 and 5x110 are dimensionally identical.
Old Mar 21, 2013 | 10:42 AM
tpete763's Avatar
If You swap to LSJ hubs and re-drill them for the conversion you NEED an LSJ front brake setup as well. Your LS rotors are too small and will not fit over the LSJ hubs.
You will need:
LSJ Hubs All around (2 front, and 2 rear)
Front LSJ Calipers
Front LSJ rotors
Front LSJ Pads
Rear drums from a 5 lug cobalt (the ones I linked to earlier)
Old Mar 21, 2013 | 10:45 AM
tpete763's Avatar
Wrong, HIS 4 LUG ROTORS WILL NOT FIT ON THE LSJ HUBS, they are too small. I tried to do this with my setup and found out the hard way. He needs an LSJ brake setup to for the front if he plans on using LSJ hubs.
Old Mar 21, 2013 | 10:48 AM
tpete763's Avatar
From what I remember the 5 lug drum is slightly larger than the 4 lug drum. I bought the 5 lug drums and re-drilled them for the rear just to be sure everything fit correctly when it was finally all together. I didn't want to run into any problems while putting it all together. the lsj hubs will bolt right up to the rear beam.
Old Mar 21, 2013 | 02:02 PM
They're only 90 bucks so that's no big deal, thanks for the info guys. Hopefully I can get a start on this soon.
Old Mar 21, 2013 | 02:23 PM
tpete763's Avatar
No problem, make sure if you're swapping to LSJ hubs that you buy the brakes, rotors, and calipers too.
Old Mar 21, 2013 | 03:06 PM
I'm just going to re-drill my rotor or buy blank rotors and have them drilled to to the 5x114 so I don't to do a complete swap like EX said.
