5-110 to 5-100 bolt pattern wheel adapters
Old May 8, 2012 | 06:18 PM
Cory05SS's Avatar
I have a question about the bolt pattern 5-110 to 5-100 wheel adapters. I just ordered the XXR 530's and the bolt pattern is 5-100. So in order to use these wheels I need to order wheel adapters. Has anyone had any previous run ins with this situation, and what mm thickness adapter would be appropriate? Thanks, Cory.
Old May 8, 2012 | 08:06 PM
Hockeyman's Avatar
i'm running 5x110 to 5x100 adapters. Offset on the rims you order is very important. For thickness, 19-20mm max. Offset of your rims will need to be 45+ depending on width otherwise it will look like poo.
Old May 8, 2012 | 09:31 PM
Cory05SS's Avatar
I have 18x9 cooper xenon tires all the way around. And for the wheels i ordered 18x8.875 (2) +20 and (2) +35. As of now I'm looking at the 20mm adapters along with a possible fender role.
Old May 8, 2012 | 09:41 PM
dandaman15's Avatar
With wheels that wide and offsets that low your going to have a hell of a time fitting those in the wheel wheels. It will poke like a ****, even if you run 215/45/18 or narrower. Without the spacers they may fit, but since your adding a 19mm spacer at the minimum that means the offset is essentially 18x8.75 0 in the front and +15 in the rear.
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
