5x110 5x114.3 with 42mm offset fit?
Old Jan 23, 2012 | 04:56 AM
nRRe's Avatar
Local guy is selling them for 200$ w/out tires and was wondering if they would work...came off a g6. they are 18x7.5s
wondering how they'd look on SRTC, think it'd be okay. looks p.similar to stock spoke design wise.
Old Jan 23, 2012 | 05:19 AM
MastaShaKe_88's Avatar
I dunno if they'll clear brembos.... but otherwise they'll fit
Old Jan 23, 2012 | 05:25 AM
tmazSS's Avatar
so is the pattern 5x110 or 5x114? 200$ is a good deal tho it seems.
and before you buy them jus mount one on the front to verify they clear the calipers
Old Jan 23, 2012 | 06:50 AM
brice240z's Avatar
Its prob dual bolt pattern an by the look of it I dont bink itll clear the brembo's because of the way it curves
Old Jan 23, 2012 | 05:25 PM
nRRe's Avatar
if i sell the BBS's off my Passat I'll test fit em, he said that was fine obviously.
Old Jan 24, 2012 | 12:29 AM
brice240z's Avatar
Why not worth a shot
Old Jan 24, 2012 | 02:37 PM
doc@tirerack's Avatar
Supporting Vendor
The redrill looks a little too close for comfort.....they might need a small spacer to clear the califers but I'd be worried that the wheel won't hold up.
Old Jan 27, 2012 | 01:14 AM
nRRe's Avatar
that is also something i noticed, on how close together the drilling is...if it was going on something slow like my Passat I wouldn't worry about it...but the Cobalt has well over twice the power and the thinness of the metal between the bolt holes kinda scares me.
Old Jan 27, 2012 | 01:50 AM
09BlueBaltSS's Avatar
Walk away
Old Jan 27, 2012 | 01:28 PM
bspeed's Avatar
why are they drilled so close? you got like a tooth pick of metal there
Old Jan 27, 2012 | 01:33 PM
BLAZIN07SS's Avatar
I'm too JDM for you
not a fan of that redrill at all
Old Jan 27, 2012 | 01:37 PM
StruttinSoul's Avatar
/\ What they said. Looks like there might not even be metal in between in some places.
Also with that concave I doubt they will clear the brembos.
I took my old rims from my G6 and used them as winters and they were concaved a bit and 18x7.5 I needed a 5mm spacer but those ones seem even deeper.
Old Jan 27, 2012 | 11:29 PM
nRRe's Avatar
:| guess i can just spray or powdercoat the stockers =P
now to convince hte wife Gold looks awesome on SRTC.
hacadacalopolis
Oct 28, 2015 06:09 PM
cavfiredesire
Oct 3, 2015 08:02 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Delta coupe
Sep 30, 2015 08:11 AM
royce777
Sep 28, 2015 07:11 AM
