Aftermarket wheels vibes / bounce help?
Old Jul 31, 2013 | 09:19 PM
bspeed's Avatar
So I had my hubs redrilled to 5x114.3 by a local guy ordered a set of xxr wheels and tire package mounted and balanced to my door
Installed the hubs, triple checked it, installed the wheels note they don't require a spacer
Then noticed a shake in the steering wheel at 45-55 mph along with a weird bounce in. The seat and feels like its common from. The front as well, then I installed these plastic Hub rings xxr included they didn't work too well I think they were the wrong size cause I didn't notice much of a difference , I'm guessing the wheels are so off center it's causing a weird hop from 30mph decel to a stop and then from a stop to about 30-35 it wants to bounce weirdest thing ever. My wheel bore is 73mm and stock is 65.1 so I just custom ordered billet aluminum centric rings hope they help , kinda lost my other sets of wheels never did this my winters do slightly but it's not as bad. They are 5x110 215/45/17 xxr are 18x9 225/40/18 I'm on bc could and its not slammed really low Also I torque the wheels to 90 ft lbs
Had a tire shop re balance them also they seem to blame the hub redrill , no other explanation
Also had an alignment few 2 wks ago
There's a gap where the hub lip meets the wheel bore obviously. Sorry about the iPhone grammar
Old Jul 31, 2013 | 09:29 PM
hmmmm
Old Aug 8, 2013 | 01:43 PM
blueLNFftw's Avatar
Try the hub spacers, cobalts are both hub and lug centric. If you get the hub centric rings on there and they still do it then most likely dude redrilled them off center.
Old Aug 8, 2013 | 07:01 PM
doc@tirerack's Avatar
Supporting Vendor
I guess you could always have the wheel checked to make sure there is no radial or lateral runout, but I'd like to think that the machine shop was careful enough with the wheels to where they are not bent. You would probably have to take the wheels to (another) machine shop to have them checked to make sure the seats and the new lug openings were machined square with the rest of the wheel.
Old Aug 11, 2013 | 10:57 AM
Kyle09TC's Avatar
well another option is getting centering lug nuts for the front to get it centered without needing rings. i have them on my varrstoens up front to center the rim since the spacer doesnt have a lip.
Old Aug 12, 2013 | 10:05 PM
bspeed's Avatar
Centric rigs helped alot but I'm still noticing a tiny hop I switched back to 5x110 and threw on my winter wheels and I noticed it aswelll which is weird hub rings I had made are top notch and fit perfect
Old Aug 12, 2013 | 10:13 PM
it has to be the suspension than, how many miles on the coilovers?
have u adjusted them lately?
Old Aug 13, 2013 | 06:36 PM
bspeed's Avatar
Not really I have the fronts at 12 from soft and rears 8 from full stiff
About 1300
Old Aug 13, 2013 | 09:02 PM
idk man
Old Aug 13, 2013 | 09:10 PM
LS6Rally's Avatar
Umm did the guy who re-drilled the hubs do it right?
You switched back to stock, did you swap hubs or stud locations?
you never answered my question, did you swap hubs to your stock, or did you change the stud locations?
Old Aug 14, 2013 | 09:18 PM
bspeed's Avatar
He claimed they are spot on i took them back to his house few weeks ago
Old Aug 14, 2013 | 09:58 PM
Powell Race Parts's Avatar
the only real way to redrill bearings right is in a fixture with a milling machine and a skilled operator. A drill press dont hack it.
sad to say the answers are like have been suggested by the tire shop.
Old Aug 14, 2013 | 09:59 PM
you think he would say otherwise? take a bearing to a machine shop and have them check one, that will tell the story.
Old Aug 15, 2013 | 06:52 AM
LS6Rally's Avatar
^ haha this.
ask a guy if he robbed a bank, he'll tell ya!
Old Aug 15, 2013 | 01:24 PM
bspeed's Avatar
No **** not looking for a smart ass remark the guy that redrill them is Jeff reliand aka mongorat, I was going by reviews and my buddies experiences with him no one else had any of these issues from his redrills.....
Old Aug 15, 2013 | 01:43 PM
blueLNFftw's Avatar
Calm down. Even the best companies with the best reputations can sometimes have an unforeseen issue. You asked for help, your getting suggestions and they are all logical to look into.
Old Aug 15, 2013 | 01:50 PM
Doesn't matter who it is **** can go wrong, have a machine shop look at them. Also when the tire shop balanced the wheels how much weight did they have to add?
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
DANRICKARD
Oct 1, 2015 12:08 AM
