AHem...
Old May 11, 2011 | 08:37 PM
  #126
BooSSted's Avatar
Yeah, it'll basically just cover the lip of the wheels. It's only 3/8" different on each side. It'll still look good.
Old May 11, 2011 | 08:45 PM
  #127
Whining-devil's Avatar
Originally Posted by ls1fbody
looks fine to me :shrugs:
And he's not doing a hub conversion lol. there are TWO delta's with conversions. One is my cobalt, the other is a blue Redline.
He ordered the wheels in his lug pattern.
His meaning = suck my dick
oh theres another one with a hub conversion
Old May 11, 2011 | 08:56 PM
  #128
ls1fbody's Avatar
Haz l33t wheelz.
conversion, or just drilled? there's a distinct difference.
Old May 11, 2011 | 09:03 PM
  #129
BooSSted's Avatar
Oh don't be mad that you did more work than you had to....
Old May 11, 2011 | 09:17 PM
  #130
ls1fbody's Avatar
Haz l33t wheelz.
Not mad, just surprised there's another one. I didn't do more work than i had to lol, maybe it wasn't necessary, but modding any car that doesn't race is unnecessary.
Old May 11, 2011 | 09:21 PM
  #131
BooSSted's Avatar
not mad, just surprised there's another one. I didn't do more work than i had to lol, maybe it wasn't necessary, but modding any car that doesn't race is unnecessary.
blasphamy!!!!
Old May 11, 2011 | 09:47 PM
  #132
09sscalicobalt's Avatar
haha this is true will this is true john powell is turning in his chair everytime he sees your hellalow cobalt will but seriously one day you should raize that biatch up and go race with me!
Old May 11, 2011 | 10:18 PM
  #133
RooTBeeR's Avatar
Originally Posted by BooSSted
I'm assuming you're going to do a lug conversion right?
If that's what you're doing, removing the adaptor plate and running wider wheels with a lower offset is going to make this car look proper! The people that are saying "It's only half an inch", I don't think you quiet understand what's being done here. I'z shall explain!! Dom can yell at me if I get this wrong. All measurement are going to be approximate.
Dom's old wheels were 18x9 with probably a +42mm offset. He used about an 18mm adaptor plate to reach a final offset of +24mm. While this gave him the stance he wanted, the wheels didn't fit the "Stance". Reason being, the spacer is what did the work and not the wheels. When you use an adaptor plate this thick, you MUST run a high offset wheel or your final offset is going to be WAY too low and your **** won't fit, lol. High offset wheels of this type generally don't look good, especially when you're going to a Stanced look.
Now, with a 9.5" wide wheel with a 30mm offset and no adaptor plate, the outer lip of these wheels should sit within' 1mm of the old wheels making the Stance look identical to the old setup from the front and rear of the car. But here is where the difference is. Because there is no adaptor, the shape of the wheel has to change in order to get the center of the wheel back to the hub. So, we take away 1/4" (6.25mm) for the additional width of the wheel, then take away 18mm because we got rid of the adaptor plate. So, what this gives us is an additional 24.25mm (a ***** hair less than 1") of additional concavity!
For those of you who still don't get it. It's gonna look sick.....
ooohhh, didnt know he was running a spacer on the old wheels that makes a lot more sense
u race?
Old May 11, 2011 | 10:39 PM
  #134
LS2SS's Avatar
sub'd for l8tr
Old May 11, 2011 | 10:47 PM
  #135
sloobaltss's Avatar
Originally Posted by DOMDOTCOM
who had 18x9 +24. NO ONE.
who has 18x9.5? NO ONE.
i guess you don't get stance...
im pretty sure I have a set im picking up friday :p
Old May 11, 2011 | 11:20 PM
  #136
u race?
haha only once so far but there going back memorial day weekend to fotana i wanna go so bad!
Old May 12, 2011 | 12:31 AM
  #137
DOMDOTCOM's Avatar
MADE STANCE COOL
ehhh..
Old May 12, 2011 | 01:52 AM
  #138
IdreamofYenko's Avatar
These ones gonna be white too?
Old May 12, 2011 | 02:07 AM
  #139
DOMDOTCOM's Avatar
MADE STANCE COOL
nope hahaha
Old May 12, 2011 | 02:18 AM
  #140
sundevil07's Avatar
nope hahaha
Old May 12, 2011 | 08:07 AM
  #141
RooTBeeR's Avatar
"cobalt" blue?
Old May 12, 2011 | 08:18 AM
  #142
cobaltj's Avatar
Is that a coblat jacked up with big tires on it ....
Old May 12, 2011 | 12:39 PM
  #143
Bumpin Balt's Avatar
Here is a 9.5" wheel with a 215. It looks retarded!
If this looks "fine" to anyone, you're smoking crack!
Old May 12, 2011 | 01:34 PM
  #144
Maupin SS/SC's Avatar
DOM GET SMALLER TIRES our cars are fail wheel drive your going to spin in first stretched at all so get 225 or 215 35 or somethign and make the stretch sexy...s15 on a 9 is a badass stretch thats what sam has ill text you a pic tonight of the difference in a wider fitting neogen and a skinny as falken 512
Old May 12, 2011 | 01:37 PM
  #145
Originally Posted by Bumpin Balt
If this looks "fine" to anyone, your smoking crack!
thats how you make **** fit you need to spend more time educating yourself instead of being ingonorant...that 215 on a 9.5 is sexy you know how far that guy can poke just cause of that tire
stancenation .com
juststance .com
stanceworks .com
fatlace .com
go to them get it right if its not your style then eat my dick
Old May 12, 2011 | 01:56 PM
  #146
DOMDOTCOM's Avatar
MADE STANCE COOL
NOOOOOO **** you hahah
<3
Old May 12, 2011 | 01:58 PM
  #147
dont you wanna be low too? how much rear camber are you gonna shim with those fat *****? just get 225 instead
Old May 12, 2011 | 02:04 PM
  #148
DOMDOTCOM's Avatar
MADE STANCE COOL
i am low, i dont need 225s. too much stretch. itll be fine
Old May 12, 2011 | 02:21 PM
  #149
stancenation .com
juststance .com
stanceworks .com
fatlace .com
I don't mind some stretch, but that is ridiculous. You need to educate yourself on what is safe and what isn't. The bead on that tire isn't even close to being set properly. I'm not looking to start a bitch fight. You're entitled to your opinion and I'm entitled to mine. Just don't try and argue that it's a "good idea" to run a tire that is stretched that much, because it could be downright deadly.
Old May 12, 2011 | 02:38 PM
  #150
007Balt's Avatar
idk....but in for results....I want to see outcome....cant wait
