annoying tires!
Old Sep 25, 2006 | 04:02 PM
Death Dealer's Avatar
annoying tires!
Ok Guys i hope u can help. I have a Set of Konig Unknowns in an 18" with the Stock tires on them. for some reason the Stock tire makes the rim look smaller and its really annoying me. Could you guys give me a good tire size and brand for for these rims so the rim actually sticks out more and is not overpowered by the tire. I would like some low profiles however, i dont want "rubber Bands". And i know the thinner tire will make the ride a lil lower not much but good enough until i change the springs. So all ur knowledge is very much appreciated
Old Sep 25, 2006 | 04:13 PM
CTCOBALTSSS's Avatar
Go with a 40 profile tire. They're not rubbers band but they are not life preservers either.
Plus any rim that has a lip like those Konigs are going to look smaller than they are.
The face of the rim doesn't extend to the edge of the rim just the edge of the lip so they all look an inch smaller than they actually are.
Old Sep 25, 2006 | 05:18 PM
Im not sure i know what u mean when u say 40. can u elaborate.
Old Sep 25, 2006 | 05:38 PM
biniecki's Avatar
Yea mine are the same way. I just got a set of 17" BSA 333 and they have a huge lip on them too and they look like 15s even with small tires on them. Only thing i dont like is that the wheel gap makes them even look smaller so im going to be getting new springs real soon
40 is the height of the tire. It is the middle number. An example of a 40 profile tire would be mine which are 215/40/17
Old Sep 25, 2006 | 09:47 PM
Tires are measured using three different measurments.
1. Width
2. Thickness (profile)
3. Rim size
So if you get 215/40/18 tires, 215 is the width, 40 is the thickness or (profile of the tire), 18 would mean they fit an 18" rims. 40 is a perfect profile. It's not too thin and not too thick. 45 is even a good profile. 50 starts to get too thick for big rims and 35s are rubber bands that just leave your rims bent from potholes.
Old Sep 25, 2006 | 10:02 PM
ecotecon18s's Avatar
1. Width
3. Rim size
Well put.
Old Sep 27, 2006 | 09:35 PM
Badmunky's Avatar
How wide are your rims? Give me that and Ill give you a good tire size.
40s might not do it for you if the rim is to wide.
I have 40s on my car right now. Look at my sig.\/
Sl0wbaltSS
Nov 21, 2018 11:11 PM
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
