Can anyone explian this?
The diameter of the tires is based off all 3 of the #'s 225 is the width in mm (metric) then 40 is the aspect ratio for the sidewall so 40% of 225 mm is the side wall of the tire. you double this then add the rim size which is in imperial 18" (you have to do some converting ) to get the diameter. Then figure out the circumfrence pi x d or just use the tire size calculator
http://www.miata.net/garage/tirecalc.html
235/40's are the best tire size..!
from 215/45R18 to :
235/40's 0.8% too fast / 60MPH = 59.5MPH
225/45's 1.4% too slow / 60MPH = 60.8MPH
225/40's 2.1% too fast / 60MPH = 58.8MPH
215/40's 3.3% too fast / 60MPH = 58.0MPH
the best fit sized tire for the cobalt are 235/40R18... nothing else..!
from 215/45R18 to :
from 215/45R18 to :
from 215/45R18 to :
I meant that your info is correct, but you should really specify the model instead of just saying Cobalt. Many people seem to be confused on tire size issues.
2.0 LSJ Engine: (How-to) Port & Polish your Supercharger!
BlilBT
How to Guide
41
Jul 28, 2016 05:28 PM
. Most people think that if it's the same sidewall series, it will be the same height.
