cracking on tires? true or false?
Old Sep 18, 2008 | 02:19 AM
dylanb02's Avatar
if you let your tires sit for a long time,
aka
till spring
do i have the chance of the tire cracking?
Old Sep 18, 2008 | 02:24 AM
ls1fbody's Avatar
Haz l33t wheelz.
you mean like dry rot? it would be best to put the car up on blocks and take most of the air out of the tires.
my car has been in storage like that for 8 months, just took it out and it was just fine.
if you just park it and let it sit, you may have some issues.
Old Sep 18, 2008 | 02:27 AM
dylanb02's Avatar
naw i mean, like.
i just bought my car off my dad.. but he cant buy a car till
spring so i get it then..
i just bought 1200 new wheels and tires.
and i have the stock wheels on right now, and i wanna know if
i just hold the new rims in like my garage.. stacked up... will they dry rot?
Old Sep 18, 2008 | 10:10 PM
dylanb02's Avatar
Old Sep 19, 2008 | 04:54 AM
maverick0716's Avatar
Not from one season.......but if you're concerned, just put each of them in a garbage bag and tie them closed. By the way, since I sold those to you, just stop by the shop and I'll give you some tire bags for them.
Old Sep 19, 2008 | 05:44 AM
ls1fbody's Avatar
Haz l33t wheelz.
Originally Posted by dylanb02
naw i mean, like.
make sure you don't let them sit on a bare concrete floor. can you get a wooden pallet? stack them on that, and if you can't use some thick blocks of wood and then put a peice of cardboard in between each one.
Old Sep 20, 2008 | 10:14 PM
dylanb02's Avatar
okay, thanks man will do.
Old Sep 20, 2008 | 10:45 PM
srowler9's Avatar
I use to drive my Honda S2000 on foam blocks that were about 2 inches thick. Worked perfect every winter. Just don't let the tires sit on a hard surface.
Old Sep 21, 2008 | 01:27 AM
dylanb02's Avatar
right now they are sitting in my room on my carpet stacked up.
should i let a lil air out?
Old Sep 21, 2008 | 01:13 PM
ls1fbody's Avatar
Haz l33t wheelz.
maybe 5 psi. otherwise you should be set
Old Sep 21, 2008 | 01:14 PM
D4u2s0t's Avatar
lay them down on their side, not on a cold ground (like an unheated garage) and you should be fine for the winter.
Old Sep 21, 2008 | 01:21 PM
ls1fbody's Avatar
Haz l33t wheelz.
they're stacked in his carpeted room.
Old Sep 21, 2008 | 01:48 PM
D4u2s0t's Avatar
yea no worries then. i keep my winter tires inside all spring summer and fall, and my summer tires inside all winter. they'll be fine.
Old Sep 21, 2008 | 02:23 PM
dylanb02's Avatar
sweet thanks, sounds good
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
