Old May 16, 2012 | 07:36 AM
  #4076
znew's Avatar
Originally Posted by RKRamos
+25mm or +35mm? Those don't look like they poke enough for +25mm that's why I'm asking. I have the same sized wheel and it looks like you're sitting about where I'm sitting now.
they poke a lot. Ive seen them in person they are +25
Old May 16, 2012 | 10:35 AM
  #4077
BLAZIN07SS's Avatar
I'm too JDM for you
Old May 16, 2012 | 11:10 AM
  #4078
sloobaltss's Avatar
16x9.5 et 12.6 205/45/16
Old May 16, 2012 | 11:57 AM
  #4079
BLAZIN07SS's Avatar
I'm too JDM for you
you put the drum axle in yet?
Old May 16, 2012 | 03:37 PM
  #4080
sloobaltss's Avatar
Not yet. Still trying to source one. Seems like the 5 bolt ones are hard to find.
Old May 16, 2012 | 04:56 PM
  #4081
awb55's Avatar
+25. The left rear doesn't poke as much as the right (damn swing arm cars). Plus falken 215's run way small so its more like a 195 or 205. A ton of stretch... Dom, Zach, and Beamer have all seen my car in person...
Old May 16, 2012 | 05:04 PM
  #4082
1LSJ2NV's Avatar
Cobalt Nation
photo dump
Old May 16, 2012 | 05:35 PM
  #4083
C_A_D88's Avatar
..... Just get a 4 bolt one and swap hubs...
Old May 16, 2012 | 05:45 PM
  #4084
awb55's Avatar
Originally Posted by seeyaass
How much were those wheels man?
$225 each...
Old May 16, 2012 | 06:29 PM
  #4085
seeyaass's Avatar
Originally Posted by awb55
$225 each...
And you had to get them redrilled or you got adapters? Looks great man... Where do you get them from?
Old May 16, 2012 | 06:32 PM
  #4086
awb55's Avatar
I'm an LS so 4x100
ESMwheels.com
Old May 16, 2012 | 07:18 PM
  #4087
seeyaass's Avatar
Thanks for the info bro!
Old May 16, 2012 | 08:40 PM
  #4088
sloobaltss's Avatar
Just scored a 5 bolt drum brake trailing arm. Pick it up next week. Should have it all built and ready by sometime in June
Camber is coming.
Old May 17, 2012 | 12:56 AM
  #4089
JUICED_SS's Avatar
Camber is coming.
Can't wait to see it! And I probably still won't have my wheels yet. lol
Old May 17, 2012 | 01:28 AM
  #4090
DOMDOTCOM's Avatar
MADE STANCE COOL
eat a dick
Old May 17, 2012 | 05:03 AM
  #4091
Jookycola's Avatar
Well I got my XXR's on the sedan. And the fitment was much better than expected.
However.
How are you sedan guys getting away with NOT rubbing your rear tires on the inner fender on those 9 inch wide wheels? I've rolled the fender and i still rub not all the time but enough I worry. What's the secret? should i stiffen up the damper on my rear shocks? Or is it just a part of what happens when you drop this car and not worry about it? I'd like a bit more low, but It looks like I'd either have to pull the fender...or can camber be adjusted on our solid rear axles? How are you 4-ddor guys dealing with this issue?
Specs:
17x8.25
Offset +25
Backspacing 5.61
Stance GR+ coilovers.
Old May 17, 2012 | 09:50 AM
  #4092
sloobaltss's Avatar
However.
Specs:
17x8.25
Offset +25
Backspacing 5.61
Are you rolled and pulled or just rolled. ? You'll have to pull it as well.
I ran 18x9.5 et35 with a roll and pull and had my stance gr+ maxed out. I was running a 225/35/18 tire. What size tire are you running ?
This year I'm running 16x9.5 et 12.6 with 205/45/16 and the rear doesn't rub either. Hsds maxed out but collars still in.
Make sure your pulled and it depends on your tire size. I have yet to rub tires at all.
Also I'm assuming your car has rear drums? If so just shim your hubs and run camber. The guys with disk brakes in the rear can't do this because the caliper bracket is part of the trailing arm, so once you shim on those cars the caliper doesn't move but the rotor does, and you end up pinching the rotor with the caliper. This won't happen on a drum brake car. So shim it to your desired camber set up.
Hope that helps
Old May 17, 2012 | 02:04 PM
  #4093
Jookycola's Avatar
Tire size is 215/45/17. My fenders are just rolled, not pulled. What do I need to pull the fenders properly? Eastwood roller?
And yes it's an LS so it has Drums. I'll look into shimming too. Since I only need a hair of clearance, and I'd rather do that than risk cracking my paint by pulling. Thanks a lot mang!
Old May 17, 2012 | 04:33 PM
  #4094
awb55's Avatar
More Crappy Camera+ Iphone pics:[IMG]
Uploaded with ImageShack.us[/IMG]
And the stretch and poke... [IMG]
Old May 17, 2012 | 04:50 PM
  #4095
stylin's Avatar
that car looks toughh!...
Old May 17, 2012 | 04:52 PM
  #4096
08ssedan's Avatar
Looks real good! ^^
Old May 17, 2012 | 05:13 PM
  #4097
awb55's Avatar
Thanks guys. Really thinking hard about wrapping it flat white and changing up the wheel colors in the near future... IDK though...
Old May 17, 2012 | 05:17 PM
  #4098
awb55's Avatar
Older pic before side skirts:
Old May 17, 2012 | 06:39 PM
  #4099
JGoodman07SC's Avatar
nice
Old May 17, 2012 | 07:34 PM
  #4100
Jookycola's Avatar
I've come to realize how important it is to have lower body cladding/body kit to finish off the stanced look since my LS still looks too high.
