Old Apr 20, 2013 | 11:21 PM
  #8376
dakotaspeir's Avatar
#cobalthoes
+25 on a 9.... gay who would do that
Old Apr 21, 2013 | 12:00 AM
  #8377
AARON-SS-TC's Avatar
That picture is pretty amazing!^^
very awesome car. cant wait till i am on this thread too.
Old Apr 21, 2013 | 11:37 AM
  #8378
TxBlueBalt's Avatar
No ET or +?
25 offset on a 9" rim is quite a bit..
Yea I checked them and it doesn't say et or have a + anywhere on them. How much would a 17x9 +25 poke, i could put it on the car and measure how much it sticks over and that would determine whether they are +25?
quite a bit sunken
what are the specs on your wheels if you don't mind me asking?
Old Apr 21, 2013 | 11:41 AM
  #8379
#cobalthoes
Picture above this post has the fronts +25 and the rears are +30 on my 17x9s
Old Apr 21, 2013 | 11:42 AM
  #8380
#cobalthoes
thanks!
Old Apr 21, 2013 | 02:13 PM
  #8381
BPacak's Avatar
Vtec Rep
i need to get new pics, its been awhile
Old Apr 21, 2013 | 03:03 PM
  #8382
Steviodaddio's Avatar
No ET or +?
The majority of XXR's wheels that are 9" and wider are in the 20s for the offset, if not lower. The highest offset I've seen on an "deep concave" wheel is +42 on the 17x9 522, the majority are +20 or +25. A +25 isn't a low offset for a 9" wheel, the majority of wheels people put on cobalt's just aren't aggressive and I wouldn't even say a 9" +25 is aggressive. Heck, XXR has their 7 and 8" wheels with 0et.
Are you sure you had XXR 522's though? They didn't make that size in a 4x100 pattern unless you bought them used from someone who had metal work done and redrilling.
Old Apr 21, 2013 | 06:01 PM
  #8383
rhamilton909's Avatar
so if i have a base model cobalt 2010. i jsut put 17x7.5 helo wheels on it. the tire size is ?/35r17. i cant rememebr the first number all i know is ovrall diameter is same as stock. how low can i go with out rubbing
Old Apr 21, 2013 | 06:30 PM
  #8384
TxBlueBalt's Avatar
Yea they are the 522's in 17x8 and 17x9, I still have three of them, just need another 17x9 to complete the set, they have two bolt patterns 4x100 and i think 4x114.3, it doesn't look like there has been any metal work done to them and if there has, it is professional enough to where i can't tell. I bought them from a tire and rim shop in Houston, i think they are a vendor for xxr, but i called them about replacing it and they said they couldn't.
I like the look of how those rims fit your car. I might end up going for the rota grids in 17x9 +25.
Old Apr 21, 2013 | 09:37 PM
  #8385
yes bish
Old Apr 22, 2013 | 01:12 AM
  #8386
9 wide in the rear
Old Apr 22, 2013 | 01:17 AM
  #8387
ls1fbody's Avatar
Haz l33t wheelz.
Bout time someone let you loose with a real camera
Old Apr 22, 2013 | 01:26 AM
  #8388
im learning ^_^
Old Apr 22, 2013 | 09:16 AM
  #8389
sebleroux08/tc's Avatar
9 wide in the rear
Is this on your car🙊!! Looks so sick
Old Apr 22, 2013 | 09:29 AM
  #8390
Finally got the car on the road this weekend went wingless and shaved the key hole spent 4 hours polishing and waxing it yesterday!
Old Apr 22, 2013 | 10:30 AM
  #8391
06_CobaltLS's Avatar
9 wide in the rear
Mmmm dat lip.
Old Apr 22, 2013 | 11:09 AM
  #8392
sergiochaotik's Avatar
loll you won't rub with a 7.5. Ever.
*edit: assuming you don't have a -197* offset.
Old Apr 22, 2013 | 11:49 AM
  #8393
iToastie's Avatar
Spacers
Old Apr 22, 2013 | 01:14 PM
  #8394
a buddy's car
Originally Posted by 06_CobaltLS
Mmmm dat lip.
x2
Old Apr 22, 2013 | 09:48 PM
  #8395
BLAZIN07SS's Avatar
I'm too JDM for you
and just because
all photos by RKR photography https://www.facebook.com/RKRamos91
Old Apr 23, 2013 | 01:46 AM
  #8396
I saw pictures of the accident. What the **** happened?
Old Apr 23, 2013 | 06:32 AM
  #8397
agita_san's Avatar
So I am having some serious issues with my axles. The outer cv joints keep getting chewed the eff up. Was told by some guys on another forum that the stance guys over here on .net talked about cutting thier axles down an inch.
The way he described it you would cut an inch out of the shaft and then reweld it.
What I would like to know is would it not be possible to remove the outer joint completely from the shaft and cut or grind off the end? And if so would there be enough spline left so that you wouldn't have to get them resplined?
Any advice you guys can give me would rock!
Old Apr 23, 2013 | 06:34 AM
  #8398
agita_san's Avatar
Saw the same pics and wondering the same thing...
Old Apr 23, 2013 | 07:52 AM
  #8399
BLAZIN07SS's Avatar
I'm too JDM for you
he was slowing down in the turning lane. lady pulled right out in front of him, he slammed on the brakes and swerved and hit car. multiple witnesses vouching for him not being at fault.
Old Apr 23, 2013 | 01:20 PM
  #8400
Marca34's Avatar
Whats this low crap all about. Nobody got time for that.
